Question about Samsung Televison & Video
Samsung big screen tv, the color is off, it was dropped
Model# PCN5425R Serial# 39ZW750Z13P The tv was dropped and now the color is off, seeing triplicate, one red, one yellow, and one green overlaying each other. How do we adjust this back to normal.
    Problem Solver:
  • 5 Answers
IM NOT OF YOUR TV TYPE BUT IF THERE IS A TUBE IN THE INSIDE OF THE SET BUT BEHIND THE SCREEN, ON THE EXTENSION OF THE TUBE THERE SHOULD BE THREE OR SIX TABS LINED ONE IN FROUNT OF THE OTHER CONNECTED OR PART OF A CIRCULAR PIECE FITTED AROUND THE EXTENSION.SIMPLE ROTATE THEM AROUND THE EXT UNTIL THE IMAGES LINE UP, THIS NEEDS TO BE DONE WHILE POWER IS ON SO BE VERY CAREFUL NUT TO SHOCK YOURSELF
Posted on Feb 11, 2012
5 Suggested Answers
  • 1030 Answers
SOURCE: Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Posted on Jan 03, 2008
  • 1694 Answers
SOURCE: i need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Posted on Feb 21, 2008
techman
  • 3130 Answers
SOURCE: too much yellow does not adjust with normal drop
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Posted on Aug 27, 2009
  • 147 Answers
SOURCE: i have a sony color rear videoprojector tv model
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Posted on Feb 25, 2011
Picture has double exposure as well as curved, color also is distorted with pink at the top of screen. It is on a good surge protector. It was fine last night and just started it this evening when we...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Samsung PCN5425R 54" Rear Projection...
Yellow tint to the screen
Either one of two problems. Color needs adjusted on the TV or the projection is going out. Depending on how old it is and much money you want to spend on it, it may be better to just buy a new TV.
Nov 09, 2009 | Samsung PCN5425R 54" Rear Projection...
Problem with my Samsung PCN5425R 54 in. projection. I am seeing double and pictured is bowed and I see red and green colors on the screen. Is this the convergence board. Is this difficult to fix? I am not...
Your convergence ic’s have failed, this is a common problem with most all projection tv’s, the repair is involved. I suggest in your case calling a local repair shop.
Sep 01, 2009 | Samsung PCN5425R 54" Rear Projection...
Double red & green lines on screen
thats a connector issue in your LCD, it might be your LCD connector have lose connections check it.
Jul 10, 2009 | Samsung PCN5425R 54" Rear Projection...
Seeing double on my samsung rear pro
The convergence IC's are definitely bad. They are not a plug-in device, they solder in so this is a big job.
Mar 30, 2009 | Samsung PCN5425R 54" Rear Projection...
Samsung tv
Convergence IC's or check for cracked solder joints.
Sep 21, 2008 | Samsung Televison & Video
Samsung Projection TV -blue colored ghost / color off
try replacing the convergence ICs and also check the resistors that power them. This is a common fault with all projection TVs.
Mar 22, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung Rear Projection screen went out.
MrPeab,
Where did you purchase the convergence amps previously? Your set takes two STK392-040 Sanyo amps and there is a high probability that that is the problem here again. The convergence amps for these units are really critical and chinese knock-offs are abundant. Is it possible that you didn't get Sanyo originals?
Another thought is what about the heat sink used when they were installed? Did you do the installation or have it done professionally?
Bill
I doubt seriously that unplugging the unit will have any affect.
Jan 30, 2008 | Samsung PCN5425R 54" Rear Projection...
Inputs
learn lip reading..... but really 1080i inputs have to cut main circuit and be processed through your main amplifier .
shorted or too low a signal at input is a start.
Jan 08, 2008 | Samsung DLP HL-P5663W 56" TV
Tv problem samsung PCN5425R 54 in.
Very easy repair....Just replace the convergence amp board part# BP95-00142E (about $80) It includes both convergence IC's and associated components (Five connectors,one screw,easy access)no soldering...
Sep 20, 2007 | Samsung PCN5425R 54" Rear Projection...
Televison & Video Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
