Question about Hoover Vacuums
Where can I find a manual for Hoover 1800 cyclonic vacuum?
No instruction manual provided - where can I find one online?
  • Sylvia Woolhouse Feb 11, 2012
    The model is TFC3185 001 - manufactured in PRC wherever that is.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
Visit homeappliance.manualsonline.com go to manuals then mfg then hoover and finally u will see the product list
hence u will be be able to download manuals from here
Posted on Feb 11, 2012
SOURCE: Hoover Fusion Cyclonic
Ok, lfitz, I fixed my problem. First I called the Sears Service Center. They told me that I would have to drop it off there, and they would send it to Orlando to get looked at. The whole process would take about 2 weeks and who knows how much money. So I decided to become my own Hoover technician. It turns out that my original diagnosis was right about the chord that electrically connects the power on/off switch at the top of the handle to the rest of the vacuum. This was extremely easy to fix so please don't be scared away, although it does require a little philips-head screwdriver action. As always, make sure the vacuum is unplugged before you start. On the back of the vacuum, there is the hook that you wrap the electrical chord around for storage (the top one). On either side of that hook are two screws. Unscrew those. Now, the small piece of plastic that has the hook on it can be carefully pulled back, or removed if you need to. Inside, I found the detached end of a coiled black electrical chord that looks kind of like an A/C adapter. This chord should be plugged into the bottom of the metal shaft that slides in and out to allow you to adjust the height of the handle. Now, adjust the metal shaft so that you can plug the black chord back into the base. Push the chord in until you hear it click. Now, put the plastic piece back in place and put the screws back in and you're done. Plug it in and give it a try. I hope this helps.
Posted on Dec 16, 2007
SOURCE: hoover fusion plus cyclonic upright vacuum
did u wait an hour for it to cool down? that mostly works?!?!?!?
Posted on Dec 17, 2007
  • 17 Answers
SOURCE: Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Posted on Jul 11, 2008
Vac Belts
  • 701 Answers
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Posted on Dec 23, 2009
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
SOURCE: hoover mach 3 cyclone vacuum
After cleaning the foam filter, it's also helpful to pull apart the cone shaped insert in the canister. Twist the top to remove the cone, remove three screws from inside the small cylinder, then remove the 4 screws around the base of the cone. Then you can wash all of the dirt out of the honeycomb-type cone-shaped piece. Make sure it's all dry before putting it back together or it'll turn to mud. Mine worked like new after cleaning the foam filter and the honeycomb cone.
Posted on Jan 29, 2010
Is there suposse to be two belts on this vacuum
yes there are two belts this link below is the manual will give you full instructions on page 11/12.
http://hoover.com/file/640/
Feb 27, 2014 | Hoover UH70040W Bagless Upright Cyclonic...
Hoover Platinum Cyclonic Bagless Upright Vacuum, UH70015 squealing sound
have you checked the belt for the brushbar it may av stretched and needs replaceing here is the manual on link below
http://hoover.com/file/556/
Feb 16, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
How to install a v belt for Hoover U5780 cyclonic
Here is a link with instructions and illustrations to help you put belt on.
Hope this helps.
http://www.hoover.com/pdfs/manuals/U5780900.pdf
Sep 10, 2009 | Hoover U5780900 Bagless Upright Cyclonic...
Electrolux velocity pet lover 1800
we had the same problem and replaced the driver belt. The only problem is that we seem to have to replace the belt everytime we hoover!
Sep 07, 2008 | Electrolux EL1000A2 Pronto Bagless Stick...
Manual
Go to hoover.com, scroll down to downloads, enter your model number which is located on the metal tag either on the back or bottom. If it is available you will be able to download it.
Feb 29, 2008 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Vacuums Logo
278 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
