Problem printing I cannot do any printing. I get the exclamation on yellow triangle mark and the message that there is a problem communicating with the printer. The black is low in ink but the colour cartridge is full. I just want to print in colour
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
The drivers for the printer are not installed correctly...uninstall the drivers reboot the PC and reinstall the drivers using the CD or download the updated drivers from manufacturer website
Posted on Feb 11, 2012
silly girl
  • 513 Answers
SOURCE: colour printing
Check the following thread, it might apply to your problem. and just as a printer can be fooled to show a low level ink, I guess it can happen the other way around. http://www.fixya.com/problems-solutions/t103191,p342983/Epson-Stylus-Photo-R300-InkJet-Printer.aspx Good luck
Posted on May 24, 2006
SOURCE: How to Override Ink Level Gauge When Using Refilled Cartridges
Amazing solution:
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Brother ink empty cyan yellow magenta..
Posted on Aug 13, 2008
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
SOURCE: HP Photosmart D7360
try to align the print cartridge. go to settings -> tools then choose align printer. you may also try to clean the print head.
Posted on Nov 01, 2008
  • 11 Answers
SOURCE: light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
Posted on Aug 17, 2009
Yellow triangle with exclamation mark permanently showing
This is the master warning light. It is a warning that another light is lit or a condition has occurred that requires review by the driver. If there is a driver information window a message may be displayed.
Example of other conditions depending on the car is:
  • Low tire pressure
  • low window wash
  • Low fuel warning
26143099-cuwo5vs5donv5atj0gwaggyx-3-0.jpg Hope this helps?
Mar 27, 2016 | Cars & Trucks
Advanced Micro Devices ATI I/O Communications Processor USB 2.0 EHCI controller driver so usb ports will work
Would you please check the device status in the Device Manager? Is there any yellow triangle box with an exclamation mark in it?
Mar 02, 2014 | Advanced Micro Devices ATI I/O...
Magicolor 7300 print window says Ink/toner waste bin full! but it's new
The clear section of the waste toner box where that goes inside the machine check that area sensor located there might have toner on it so the printer thinks the waste toner box is full
Apr 16, 2012 | Minolta magicolor 7300 Laser Printer
Error message, print requests stuck in que
you might have multiple prints loaded
make sure you have the printer turned off it might load another page to be printed
you will need to open up a page you are about to print click ok
a page will open with a display print que tab
you will see all of the prints you have loaded
right click on the ones you dont need select delete
hope this helps
Nov 19, 2011 | Brother MFC 420CN All-In-One InkJet...
I have a light on my dash with an exclamation point enclosed in what looks like parenthesis with verticle lines underneath. It's yellow. Do you know what it is?
If it looks like a deflating tire with an exclamation mark inside, its the check your tire pressure light.
If its a triangle with exclamation mark inside its the check engine light.
Oct 03, 2010 | Volkswagen Jetta Cars & Trucks
I have a yellow triangle with an exclamation mark
ESP = Electronic Stability Program malfunction indicator lamp (MIL)
1. You can try to disconnect the battery from car terminals, waiting for 30 minutes and connect again the cables in order to reset the ESP Electronic Control Unit (ECU).
2. If this procedure does not work you must use a diagnostic equipment connected to the Data Link Connector (DLC) of the car. The ESP ECU fault memory can only be accessed and erased using diagnostic equipment connected to the DLC.
Note: ESP function includes ABS (Antilock Braking System) function!
Mar 31, 2010 | 2002 Audi A4
Printing error with PowerPoint
Reinstall the software from hp website and download the latest version. that will fix the issue. Before that what you can do is go to start-right clcik computer and go to propertoes and then go to hardware and then to DEVICE MANAGER.is you see any yellow triangles or exclamation marks . right clcik and update all the drivers. that will fix the issue.
Sep 20, 2009 | HP Photosmart C4580 All-in-One InkJet...
Problems logging into facebook - re: yellow triangle with exclamation
When you get to facebook, look in the bottom left hand corner and double click on the little world icon and click add site. You want to add facebook to the allowed site list.
Jun 01, 2009 | Facebook Social Network
Brother HL 5240 won't print
Right Click on My Computer, and select Manage. Look at Device Manager and look for any yellow exclamation marks. It may not be installed.
Apr 21, 2008 | Brother HL-5240 Laser Printer
jasbo
jasbo
