Question about Toshiba Televison & Video
Have a Toshiba 42A3000 flat screen tv and have returned from holidays to find the picture showing contrasts. I have tried other channels, turning off & on and changing settings but no change. Plea
Have had no problems previously ... now picture in contrasts
SOURCE: goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Posted on Mar 03, 2008
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
SOURCE: My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Posted on Jul 26, 2008
SOURCE: When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
Posted on Aug 02, 2009
On my 7" wide screen model TL7001-TP-ASC with ATSC Tuner. When I change the channel it wont tell me what channel the tv is on and the tv guide wont show. The tv does not show no numbers or letters
LG LED TV won't show program information or channel name ...
www.tomsguide.com/.../54774-4-show-program-information-channel-na...
Oct 18, 2011 - 17 posts - ‎7 authors
I will get the picture/sound (up to 1080i) but i can't get the TV to display the information (What I'm watching and the channel's name). It used to ...
ChanSort download ' SourceForge.net
sourceforge.net > Browse > Multimedia
Rating: 4.5 - ‎23 votes - ‎Free - ‎Windows
Jun 5, 2015 - ChanSort Channel List Editor for Samsung, LG, Toshiba and Panasonic ... ChanSort allows you to organize your TV's channel lists on your PC.
Jan 13, 2016 | Televison & Video
Toshiba 37XV505D. Sound but no picture
Since sound is ok but there is no picture, you should try the following:
1) check whether brightness & contrast controls are adjusted properly. If necessary increase level of these controls.
2) If brightness & contrast are ok and even then there is no picture then most probably, there is fault in the horizontal supply circuitry which drives picture tube and is responsible for picture to appear on the screen. you will have to take the TV to service center.
Good luck and Good day.
Rating the solution is appreciated please.
Aug 19, 2010 | Toshiba Televison & Video
Mitsubishi 50 real projection blue screen
Turners are Bad Signal Board Call Encompass Parts 1-800-638-3328 or your nearest Repair Shop.
Dec 31, 2009 | Televison & Video
White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Dec 04, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
I have a 32A14 Toshiba TV. At full screen, the
you have to take in affect on how old is the tv if you have had it a few years then the screen is going out and will only be a matter of time before it goes all the way out and you will be buying a new one if it not old and its one of the newer flat panels then its the signal that the tv is receiving if its hooked to a digital antena then you only get max of 720 from it on certain channels no matter if the channel or channels are showing hd with out a hd source your tv will not show better then that i have a 42 inch hd flat panel and use a antena and the best i get from my hd broadcast channels certain times will i get true hd like when the news is showing or when one of the series that was filmed in hd is on other then that i only get a 720 picture instead of a 1080 most commercals are not film in 1080 but in 720 max and i dont know why makes no since
Aug 28, 2009 | Toshiba Televison & Video
White line accross screen holds when picture goes up and down.
This can be caused by the contrast being set too high. Typically, for a Sky box the TV's contrast should be set to around 65.
If this does not help, then the LCD panel is probably at fault.
Apr 25, 2009 | Philips 32PF5531D 32 in. LCD Television
DVD/VCR picture (and sound) are not on tv screen
Try setting the TV to AV1 & see if the dvd picture appears.There should be a button on the remote to change TV/video. Hope this helps.
Dec 24, 2008 | Sony SLV-D300P DVD Player/VCR
TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
i suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Mar 21, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
