Question about LG Computers & Internet
LG W53Series W1953S
Lg flatron W1953S, the screen shows some different color when i start the lg flatron L1953S, the colors are different, like the white. what that problems..?? help me pleas...
  • 51 Answers
SOURCE: LG FLATRON E700SH is not displaying RED color
there is ovbiously a fault with the monitor and w ould be best if you bought a new up to date monitor then if any faults consist with that one you could just take it back
Posted on Dec 06, 2008
  • 62 Answers
SOURCE: my lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Posted on Dec 20, 2008
SOURCE: LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Posted on Apr 12, 2009
SOURCE: I have a similar problem, please let me know if you have the fix
Hello
This is RGB issues the problem is in the CRT Board where the RGB is, this need to re solder the RGB board or CRT Board maybe you have cold solder...
Angel
Thanks...
Posted on Aug 02, 2009
  • 5 Answers
SOURCE: My Lg Flatron W2241T is doing this strange color
Check to see if the color change is evident when you wiggle the back of the monitor cable going out of the PC. If this causes the sympton you most likey have a poorly grounded backing plate. It should ground the video to the chassis. If it is loose sometimes merely resting the case on the cord will keep it from shifting, but just as easily you should recrimp the edges of that little plate to your PC case. If it is on video card make sure the retaining screw is tight.
Posted on Aug 24, 2009
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
LG 47lv5500 shows wrong colors
Hi, Probably you are gonna have to change the main board! Best Regards! Bye!
Serge!
Jul 03, 2015 | LG 47 47LV5500 47 LCD TV
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
My lg flatron l1953s does not power up. the power cable is not broken or cut. it sents power but my screen doesn't power up
check the connection to the pc.If the VGA connector is not connected to the pc the monitor is not power on.Better check the VGA cable connection and fix it.
Oct 04, 2010 | LG MNTR |LCD 19' 5MS L1953S-BF RT 19 inch...
I cannt find driver for monitor LG L1953S
Actually, you should be able to use the monitor without installing a driver. If it isn't recognized automatically, just set the resolution to 1280*1024 pixel and set the screen refresh rate to 60Hz:
In Windows XP right-click on the desktop, open the Properties dialog, select Settings and set the screen resolution. Click Advanced, select the Monitor tab and set the screen refresh rate. If the proper resolution was not available in the first dialog, uncheck "Hide modes that this monitor cannot display" and try again.
That being said, there is a "driver" package, also containing a color profile, available from LG here.
If this doesn't help, describe your problem in detail, let us know your operating system and which which monitor you are currently using.
Mar 20, 2010 | LG L1953S - flat panel display - TFT - 19"...
My LG Studioworks model CRT monitor is not showing color properly.
Try Checking All The Cords
If It Works Out Ok Then Go To Your Monitors Menu Or OSD And Select RGB Or Colour
Play Around With Those Settings And See If It Makes A Difference
Jul 28, 2009 | LG Flatron 775FT 17" CRT Monitor
LG flatron L1715S
Hi, have you read the manual? More importantly have you installed the display driver on your machine?
LG L1715S Product Support Manuals Warranty More LG
Jan 28, 2018 | LG Flatron L1715S 17" LCD Monitor
My lg flatron L1730S, the screen shows some different color
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
Computers & Internet Logo
65 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
