Question about IBM Computers & Internet
Got used thinkpad 2647 and cant get it to go to BIOS
My mother in law gave me her Thinkpad and when I enter the password it gives me an error message about date & time not being correct. I cant seem to get into BIOS utility or anything else I have tried. I used it before many times and never had this problem. How can I set date and time if it wont let me in the utility program?
  • IBM Master
  • 32,281 Answers
Press the F2 function key when you boot up the Thinkpad to get into the BIOS configuration.
Posted on Feb 12, 2012
SOURCE: free ibm t21 2647-4bu restore cd download.
i have problem with my t21, it always hang up after several minutes,dont know what makes it freeze,it happens after i installed xp prof. help please
Posted on Jan 19, 2008
geekofcomp
  • 47 Answers
SOURCE: IBM thinkpad 2647 T21 LAN Card Driver files needed...
if you are using the internal LAN card to connect to the cable modem, no additional drivers will be needed. However, you would need to configure TCP/IP settings to use a DHCP server to automatically configure the IP address. you would also need to check whether or not you have the right CAT-5 cable. you might need to buy a crossover cable.
hope this helps
Posted on Apr 08, 2008
sharad84
  • 67 Answers
SOURCE: Password Removal
Need to refix cmos battery
Posted on Jun 27, 2008
  • 848 Answers
SOURCE: bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Posted on Feb 03, 2009
SOURCE: ibm thinkpad r51
What is the default password for my R51 Thinkpad by IBM Model # 2888?
Posted on Apr 30, 2010
Reset bios laptop ibm thinkpad 2647
Turn the computer off.
Turn the computer on, and immediately look for a message on the screen, e.g.,
press <blah> to enter BIOS SETUP
or
press Enter to interrupt normal startup
Press the specified key. Then, choose to enter BIOS SETUP.
Use the arrow-keys on the keyboard to navigate to 'LOAD BIOS DEFAULTS'.
To reload those settings, just press the Enter key.
Feb 12, 2011 | IBM ThinkPad T20 2647 Notebook
How do i get into bios on a ibm thinkpad 1800/R52? seems like it needs a password. all i want to do is reinstall windows and i cant boot from cd
helo
go to the link below to get further assistance
but basically to reset the password, follow these steps.
If the Power-on password (POP) is forgotten and the Supervisor password is known, simply go into the ThinkPad BIOS setup utility and reset the Power-on password, otherwise try the following:
  1. Turn off the computer.
  2. Remove the battery pack.
  3. Remove the backup battery (CMOS battery --size of coin- located on mainboard, requires you to remove the plastic cover on rear on computer)
  4. Turn on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The POP has been removed.
  5. Reinstall the backup battery and the battery pack.
    Note: Some ThinkPad systems have the ability to reset the Power-on passwords in the ThinkPad BIOS setup utility if a Supervisor password has been set.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-59377
if this helps, please rate my service -- if not let me know - i will continue to help
Nov 22, 2010 | Lenovo ThinkPad T21 2647 Notebook
Hello how to reset bios password of ibm thinkpad t23 2647
To unlock the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Take care.
Nov 19, 2010 | IBM ThinkPad T23 2647 Notebook
My mother-in-law's IBM Thinkpad will not boot. When she turns it on, there is just a lock icon at the top of the screen. It is a secondhand laptop, but it worked just fine for a few months. What could be...
Someone has got into the BIOS configuration and entered a Power On Password and when you enter the correct password you can then enter the BIOS to remove this password or allow the laptop to boot up into Windows.
This password is stored on an EEPROM chip and there are no backdoor passwords available.
The Power On Password is used to protect the laptop from unauthorized access.
Dec 13, 2009 | IBM Computers & Internet
IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
Sep 15, 2009 | IBM ThinkPad T22 2647 Notebook
Thinkpad T20 2647 HDD problem
on restart enter setup or bios and set to default settings
then restart and press f7 choose option to boot from cd
then press enter should boot.
if not then this is the site i use for bios updates www.wimsbios.com
don't forget to rate me
thanx
Feb 02, 2009 | IBM ThinkPad T20 2647 Notebook
I'm locked out of my ibm thinkpad 2647. I have forgotten my password and it has locked me out
Start the computer and hold down the DEL Key (this is usually the key to enter the bios once you enter the bios there is a section on passwords and you can sometimes select no password Another way is to remove the bios battery for a minute
Jan 22, 2009 | IBM ThinkPad A21m 2628 Notebook
IBM THINKPAD TYPE 2647
Sorry could not do any thing with this case!
No crack for password available to me till !!
Oct 31, 2008 | IBM ThinkPad T20 2647 Notebook
I forgot my bios password
Hi Marbz,
Read this article may be helpful to you
http://www.dewassoc.com/support/bios/bios_password.htm
And not to forget rating me.
Regards
ELLIN
Sep 17, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
64 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
