Question about Car Audio & Video
My sony cdx 616 multichanger has no power - Car Audio & Video
Cdx-705
Most cd changes only work with like brands. Sony with Sony .jvc with jvc. Find a manual for a brand new model on google or the the manufacturer and see if it has a problems section
Dec 27, 2013 | Sony Cdx-705 10-disc Intensified Shock...
Can't get my Sony Xplod CDX-GT200S to power on.
hi firstly check that there is power going to the player check fuses in line with the player if all ok the problem lies within the player ,but more than likely its just a power source
Mar 18, 2011 | Sony XPLOD CDX-GT200 CD Player
Unhooked the harness in order to install an FM modulator. Now, after plugging back in, I get no power on. Any ideas?
Have you tried resetting the unit? Here is a link to Sony for your CDX-4000X operating instructions. Reference page 6 for the reset proceedure.
http://www.docs.sony.com/release/CDX4000X.pdf
And here is a link for wiring pinouts, fuses....etc.
http://www.docs.sony.com/release/specs/CDX-4000X_Spec_Sheet.pdf
Dec 04, 2009 | Sony CDX-4000X CD Player
I need a wiring diagram for sony cdx-m630
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 27, 2009 | Car Audio & Video
Sony CDX-F5700 no longer sees Sony 10-disc changer
face plate is going bad lcd is fading solution--replace face
Jun 21, 2009 | Sony CDX-F5700 CD Player
Had to have my battery jumped and since then I do not have power to my sony cdx gt210
pull the unit out of the dash if applicable and inspect the rear of the head unit(deck) there should be a mini fuse in the back of the unit or inline with your power supply to the deck sounds like you just blew a fuse
May 08, 2009 | Sony CDX-GT210 CD Player
Connceting a pioneer cdx - p670 to avic x1 head unit
the changer is either incompatible or the changer wire has been intrnaly dammaged to much bending shorts them out as the wires are no more than alluminum foil enclosed in shrink wrap
Dec 28, 2007 | Pioneer GPS AVIC-X1 car radio
Cannot play my portable audio device with Sony cdx c500x
It will only accept audio from the bus in conections when a multi changer is connected and selected.
This is how I connect my mp3 player to my sony.
Swap multichanger audio outputs at the rear of the stereo for my mp3 player, press source to select multichanger.
Remember as I said, if there is not a control cable connected to your multichanger it wont wotk!
Aug 17, 2007 | Sony CDX-C5000X
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
