Question about Belkin Computers & Internet
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
  • 35 Answers
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Posted on Oct 24, 2008
I have a Belkin Wireless G Plus Router connected via Ethernet cable to a Scientific Atlanta cable modem supplied by Virgin. I can't currently get any signal from the Belkin to my MacBook Pro (I've got it...
Make sure the IP of the Router and the IP of the MAC is in the same scope.
E.G. Router: 192.168.1.1 Subnet 255.255.255.0
Mac: 192.168.1.5 subnet 255.255.255.0
Typically the router acts as DHCP-server and distributing ip-adresses automatically, when a computer is connected. But the the IP can also be set manually.
Mar 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I bought belkin g wireless modem ruter but they didn't give me CD . How can i install this and how can i use my wireless ruter please. Thank you.
Power-off your cable-modem (or DSL-modem).
Use an Ethernet cable to connect from the modem to the WAN port on your router.
Use another Ethernet cable to connect from one LAN port on your router to the network-port on your computer (desktop/laptop).
Turn the modem on.
Turn the router on.
Turn the computer on.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like:
Default Gateway . . . . . . . . . : 1234.678.0.1
Start Internet Explorer
Type http://1234.678.0.1
to access the web-server "inside" the router.
Run the Network Setup Wizard.
Run the Wireless Networking Setup Wizard,
to pick an SSID, an encryption-level (use 'WPA')
and to pick a network-password.
Now, you can disconnect the Ethernet cable from the computer, and try using the wireless-adapter inside your computer.
Sep 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
How to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
Apr 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless Router
1. you need to put the software belkin installation disc into the girls laptop not just the desktop.
2. you need to plug the modem back in
3. on the back of the router press the little button NOT THE RESET BUTTON MAKE SURE IT IS THE LOCK BUTTON it will ask you for a password on the laptop
May 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
CANNOT CONNECTTO BELKIN G+ MIMO
Hello, Connect a crossover ethernet cable from the computer to one of the LAN ports (usually 4 grouped together) on back of router. Connect a crossover ethernet cable from DSL modem to the WAN port on the back of router. Enter The default address for a Belkin Wireless, 192 168.2.1 into browser address window. Hit enter, it will then ask for a password only. For default leave it blank and hit enter. You can change it later. This lets you into the settings. Look for WAN settings and make sure the "Dynamic IP" is selected. Save this and refresh the link. Bring up a browser and check for internet connection. There's a number of changes that can be made here. Let me know what happens.
Mar 13, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Mimo Router
If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wlan connection problem
please be specific, what exactly is happning???
Nov 07, 2007 | Acer Aspire 5630 Notebook
Belkin F5D77230-4 - connecting to modem
k ur modem is usb one either u need to change the modem has ether net or get a convertor like usb to ethernet better contact isp and change the modem rate me solved if its help full
Oct 30, 2007 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
167 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
