Question about Zanussi Refrigerators
I've just stuck a small hole in side of the freezer, while trying to chip away the ice that had gathered there. Stupid? Me? Chuck it out and buy a new one?
  • 21 Answers
Hiya Jonathan. If it's just the plastic that there's a hole in patch it up with araldite or superior glue. If there's a hole in the tube then that will be no good and you will need to buy a new one. Hope i was of some help to you, kind regards.
Posted on Feb 11, 2012
  • 132 Answers
SOURCE: Peirced Freezer tray
i really hate to be the one to tell you this but you have destroyed the freezer the cost of repair out weighs the cost to replace next time use only plastic tools and a hair dryer helps move things along sorry to have to tell you this glenn.......
Posted on Nov 22, 2008
vanni7
  • 163 Answers
SOURCE: Icing in Freezer Compartment
Hi!! your drain line is plugged its inside your freezer compartment. look at the back wall on your freezer and fins you see is called evaporator try to remove the cover and get a hair dryer and melt all the ice that you see in the bottom portion of the evaporator..you should see a small hole at the bottom of the evaporator that your drain line unplugg it..Or you can do it the old fashion way just turn it of complete for 2 days and all is fine..Good luck..
Posted on Jan 04, 2009
tborn6
  • 700 Answers
SOURCE: the hole that drains water away at back of fridge is blocked
your going to have to take a wire and gently try to clear the drain line and then run water down it until its completely cleared out.
Posted on Mar 25, 2009
  • 454 Answers
SOURCE: chipping away ice in magic chef freezer section i
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Posted on Feb 06, 2010
sonicboomele
  • 1557 Answers
SOURCE: I have a small GE refridgerator and last night
you have peirced the main gass line thus releasing all the gas from your fridge it wont get cold having it sealed and re gassed cost more than a new frige time to get a new frigde /sorry/
Posted on Apr 21, 2010
WHY IS MY SIDE BY SIDE WHIRLPOOL leaking water onto floor?
normally caused by a clogged drain in back of freezer . check to see if you have ice build up on bottom of freezer..... gently chip away ice in freezer and turkey baste hot water into drain hole until water flows freely
Aug 27, 2014 | Whirlpool Refrigerators
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My GE GSL25JFPEBS side by side refrigerator stopped making ice. The green power light blinks indicating ice being stuck, but once the ice is removed from the mould, the problem starts all over again. It...
i am wondering if ice is constantly getting stuck or are the cubes smaller that the size of the mold? if that is the case have you tried replacing the water filter. The typically reason ice gets stuck in the mold is because the individual cubes (usually 7 or 8 per mold) are too small,the leading cause of that is not enough water in the mold
Also is water dispensing through the door with good pressure, if no replace filter but first check the pressure of the incoming water from house plumbing
Jul 29, 2011 | GE Refrigerators
Will trying to chip away ice in the small freezer part i punctured something. How will this effect the fridge? Will the fridge still stay cool, and just the freezer part not work, or do i need to buy a...
If you've punctured a section that allows the refrigerant gas to escape, the following can happen:
1. If you switched the unit off immediately after, then the puncture can be sealed, and the unit 're-gassed'.
2. If the unit was left to run, there is a real possibility that the compressor could sieze, resulting in repair costs that would exceed replacement costs.
Jun 08, 2011 | Refrigerators
Keyless chuck is stuck open
That can happen if the jaws inside the chuck, usually 3 triangular pieces get jammed together. With chuck facing down tap chuck several times to loosen jaws. If that doesn't work spray a small amount of WD-40 into chuck and try again
Feb 23, 2010 | Garden
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2010 | Freezers
Lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Jan 05, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
Jan 04, 2009 | Refrigerators
Refrigerators Logo
76 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
tony denham
Level 1 Expert
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
