Question about GE Washing Machines
Any way to clear the drain valve regularly without taken it out of a machine
Is there any stuff or trick that can be used to clear the drain valve, drain membran from washing power residues and water lime scale? Apart from using backing soda or essig?
  • 21 Answers
Hiya, try using bicarbonate of soda instead of washing powder about once a month. Use it to wash towels, not clothes. i find that keeps my washing machine clear of any particles. hope that is of some help to you, kind regards.
Posted on Feb 11, 2012
Testimonial: "yes I also think so I use backing soda concentrated liquid, let gasket and parts soaked in it for 12 hrs I found most of the lime, washing powder residues disappeared too. it also eliminate the smell. I only not sure whether to used it in side the machine, without disassembling parts from it. Thanks to mention wash towels, not cloths."
  • Pauline John Feb 12, 2012
    Hiya Khai, thankyou for getting back to me. Bicarbonate of soda is used in cooking and it's very good for cleaning a lot of things. It's not a liquid it comes in powder form. You can put it inside the machine and in the powder draw. Hope it works as well for you as it does for me kind regards.
Whirlpool dishwasher, quiet partner 1. Does not drain, does not finish wash cycle.
ensure your dishwasher pump and drain hose are unobstructed. If your machine does not drain it will not refill with fresh rinse water and since it can't do that the cycle will never finish.
Many people don't completely rinse off food stuffs from their dishware, expecting the dishwasher to take care of it. To be honest, a dishwasher is more of a fine cleaning and disinfecting device than a pot scrubber. Because of this, grease, food debris, etc can clog the pump or drain line over time. be sure to use a good de-greasing agent regularly once the flow of water has been cleared (don't wash your dishes with it however)
Mar 20, 2015 | Whirlpool Dishwashers
Hotpoint wmud962
bidatw . com the cheapest software you can get!!!!!!!
Jan 17, 2014 | Washing Machines
Washing machine will not drain
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Sep 26, 2012 | Bosch Washing Machines
Whenever I use it ,it stops at 15' and the delay button will be flashing, If I swicth if off and start again it will start again from 15' and stops without draining the clothes.Please help!
Please check the inlet flow at the inlet valve and also the water level sensor. If the water flow is low then the time taken will be more and so it can cause errors.
So remove and clean the inlet valve/filters , check the water level sensor and also check fianlly the drain pump for dirt clogging and not allowing free flow drain.
Finally check the controller outputs with a meter to confirm the program controller.
Sep 17, 2011 | Hoover Washing Machines
Samsung 326las will not drain, It is built in and cannot get to back of the machine. I will have to take a big built in apart to get to the backside. Is there anyway to make it drain without getting to the...
Jul 16, 2011 | Washing Machines
I just opened my pool this week. Water was pretty clear. I use the vaccum, on waste with port 1 which leads to skimmer. I added chemicals yesterday....I was wondering when the pump is running regular for...
the trick is to start with the pump pulling from the main drain, you will see air pocket in the pumps basket (most cases) turn the valve back slowly towards the skimmer as soon as you see the air pocket disappear, You have the perfect blend between the two sources. and a happy pump.
Jay the pool pump motor repair guy Longwood Florida
Jun 18, 2017 | Hayward SAND FILTER, PRO SERIES
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
How do clean a water heater tank
That process can be very difficult if you have not done it in a long time or have never done it.
Hopefully your plumber installed a shut off valve on the cold water pipe you will need this.
Also make sure you have a new relief valve handy, you will probably need that also.
First turn off the cold water to the haot water heater and also shutoff the gas ore electric to the heater.
Then hookup a hose tot he drain at the bottom of the tank. Open the valve and relieve the pressure. The you will have to lift the handle on the relief valve to allow air to go in to the tank so the water will go out.
When the tank is empty, you then need to alternately run cold waterinto the tank and then drain it out until you get only clear water out of the tank each time you do this. You do not have to run a lot of water in at a time, A half minute shot each time will do the trick.
When the water runs clear when draining the tank is clean.
Close all valves and change the reief valve, because it probably will not seal again.
If **** plugs up the drain valve, you may have to take off the hose and use a wire to clear it or even repalce the drain valve.
This is a slow and long process to do it right.
Heatman101
Feb 03, 2010 | Sewing Machines
AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Feb 10, 2009 | AEG L12700ViT Front Load Washer / Dryer
Washing Machines Logo
344 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
