Question about HP Computers & Internet
PC turns on but shuts down after
Green light on power supply
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
Shutdown may be caused due to following reason:
overheating
power supply issue
motherboard failure
remove anny external devices if connected to PC...lke graphic cards, wireless cards, external USB or HDD and try
Posted on Feb 11, 2012
  • 749 Answers
SOURCE: COMPUTER POWERS DOWN AFTER 3-4 MINUTES
In addition to that, check also the heatsink on the processor if it needs dusting, it may be filled with dust that it doesn't allow air to pass through to cool off the processor.
Please keep us posted.
Posted on Nov 27, 2007
  • 34 Answers
SOURCE: power supply
Actually that means your motherboard has burned out and needs to be replaced. Your power supply is reporting ok with the blinking light. Depending on your model it could cost between $200-400 for a tech to fix.
Posted on Sep 11, 2008
technotech
  • 183 Answers
SOURCE: lost power
unplug all the cables including power cable...
Then Press the Power button at the Front and hold it for 20 seconds
then connect the Power cable and monitor cable and turn your computer back on.
i am sure your computer is going to turn back on.
and if it doesnot turn on ask me again i can give you more help for the same as i am a Desktop Engg. and worked for HP and working for IBM now.
Thanks
Posted on Oct 26, 2008
  • 125 Answers
SOURCE: Hp pc m7640n won't turn on and power supply light is out
OK, this can be a hard thing to fix. Most of the time, the power supply is the first thing to go on a PC. However, when you stated that the motherboards LED came on after you unpluged the PS from the motherboard, it leads me to believe that the motherboard is the issue but the power supply might be outputting higher voltages and the motherboard might be shutting down. Since the power supply is cheaper then most motherboards, I would recommend getting a new one. Check ebay for a new power supply. It should be about $20 with shipping. If the same thing happens, then you need a new motherboard...
Posted on May 30, 2009
wildbear6
  • 192 Answers
SOURCE: My xps 420 pc desktop wont boot. Shut it down last
Try and reset your CMOS and see if it helps.
If you're not sure how, then unplug the power cable from your PC, then take off the side panel, on the motherboard is a set of 2 or 3 pins to Clear the CMOS (reset the BIOS) all boards are different, so there is no set location for the CMOS pins, if you're unsure, just remove the battery from the motherboard for about 30 seconds, then replace it ("+" facing up)
But you need to make sure your PS is not plugged into any external power source while you're doing this or you risk deleting your BIOS
Hope this helps in some way.
Posted on Jan 01, 2010
Bad power supply?
Do yo have a volt meter or an atx psu tester?
you can check voltage to see
If a power supply is bad, your pc will turn off or/and turn on and turn off. As long as your system is running without and shut downs your good.
However if your pc is turing off, I would change it as soon as you can. basically what is happening, when you unplug everything there isn't much of a draw on power so the light remains steady, but when you plug devices in there is a draw and the PSU cannot deliver.
I hope this helps.
Sep 07, 2009 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
My Everex Impact GA3400 acts as though it is not getting any power to it. It was working fine and just shut down and now I can't get it to start
it could be a busted power supply. check if the green LED lights in the motherboard when the unit is plugged (even if it is not turned ON, it will light). If the led is not lit, the power supply is defective.
Jul 25, 2009 | Everex GA3400 PC Desktop
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Turns on, then shuts down before anything shows on monitor
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
