Question about Kenmore Elite 45986 Front Load Washer
Pump wires I have a kenmore elite washer, model 110.42922200. The propeller is broke off. If I get a new pump how do I disconnect the wires? Do they just unplug? Thanks Steve
  • 5,911 Answers
Yes...there is a simple disconnect plug on the drain pump. The pump can be purchased at searspartsdirect.com. Just type in the model number you have provided and look under the "Pump and Motor" heading. The pump is listed as Item number 10 (part #280187). If you need instructions on how to replace the pump, the following link provides the steps necessary:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
Although the symptoms are for a pump that is NOT running, it is commonly found that even a running pump with impeller problems will cause drain problems. I hope this helps you. If you've already accessed the pump, then you're ahead of the game. I just wanted to provide you the instructions in the event that you have questions. Let me know if you need further assistance.
Posted on Oct 23, 2008
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
Kenmore elite he4t f33
The F33 code can indicate a bad pump or a problem with the wiring either at the pump or the CCU (central control unit), or the wiring harness itself. Before you replaced the pump, did you test the resistance in the wiring harness?
Unplug the washer and use an Ohmeter (VOM) to test. See http://media.fotki.com/1_p,wtftddqbdtwbdkrxgtqsskgwtqkq,vi/tgdkbwkswxfddbwsbdbxtbgtgwftb/1/1303472/5961857/image49983img-or.gif for the schematics of the wiring for the pump on the CCU. To access the CCU, you need to remove a few screws on the back of the top panel. You remove the lower service panel on the front of the washer to access the pump. The wiring should read 12.3 ohms at the CCU. If you get a reading of infinity (open), check the pump. If the leads to the pump motor give a resistance of 12.3 ohms, then the wiring harness should probably be replaced. If the circuit to the pump is fine and the error persists, then the CCU is faulty and needs to be replaced.
I hope this helps. If you add a comment with the specific model of your washer, I may be able to give additional suggestions.
Dec 23, 2012 | Kenmore Washing Machines
Where is the pump located?
It is attached to the motor.
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
How do i get the top off of a top load kenmore oasis washer to look at the water pump
5
6
7
I have a Kenmore Elite top washer and was wondering how to lift the top to clean
5
6
7
Jun 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Need to disassemble a kenmore elite oasis dryer
5
6
7
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Getting to the pump on whirlpool calypso
5
6
7
Apr 10, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Clicking in the water pump for the Kenmore Elite H3 Washer
F2 if nothing in pump replace pump, propeller inside is bad. "less soap plz "
Nov 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 3t washer
unplug machine, go down to the pump motor and squeeze the tab and connector and pull it away from the pump.
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
53 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
