Question about Dishwashers
ASKO N516 type: DW 20.2 f2 - Dishwashers
2 Suggested Answers
  • 842 Answers
SOURCE: I need a manual for
I went to the Askousa website and located manuals for your model, the link below will direct you to select your current model, you can download all your information and manuals from this site.
I hope this helps
www.askousa.com/customer-care/technical_documentation/
Posted on Aug 14, 2011
I need a manual for my dishwasher ASKO N516 type: DW 20.2
I hope this helps
Aug 14, 2011 | Dishwashers
Looking for ASKO 1555, DW 95.4 dishwasher service repair manual
Go to this link www.foggyfacts.blogspot.com/2010/04/asko-dishwasher-service-manual. Hope that helps. Let me know..
Jul 25, 2011 | Dishwashers
Asko d3350 has the f2 flasing and pump just runs
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. If it doesn't come off then you will need to remove either 1 or both of the side panel, its just a number of screws holding them. Then see if you can see where the leak is coming from, you may need to order a new part. Hope this helps.
Mar 03, 2011 | Asko 24 in. D3350 Dishwasher
Asko 1755 dishwasher. The pump keeps running We need to replace a new PCB P/N: DW955 8057931-05 Is it available?
My Asko Model 1585, Type DW 95.4 Circulation pump just died. I have the following parts available (All in working condition):
* 8057931-05 Control Board (this is the replacement part AFTER the recall)
* 8057083 Drain Pump
* 8057085 Fan circulation module (the one in the dishwasher door)
* 8057077 Heating Element
Photos and motor/coil/element resistance values available on request. I have no prices listed as I am still trying to determine their value. I am an old Boy Scout & NOT out to screw anybody.
Feb 20, 2011 | Dishwashers
Dishwasher is making a loud pipe rattling sound
The water supply line has not been secured properly. Turn off breaker, open DW at bottom and secure water line.
Sep 26, 2009 | Asko D1706 Built-in Dishwasher
Asko model 1485 Type, DW 95.3. No water supply. Inlet valve needs replacement? Where can I find a parts repair manual for this unit?
I have an ASKO 1485. It overfilled and know it will not stop flashing the lights on the panel. I have manually removed the water
Sep 08, 2009 | Dishwashers
ASKO D1706
look at the pwr supply box on the dw check for a short to ground in the main pwr wires, otherwise the only field in the dw to trip to breaker is a mtr dead shorted to ground. if that is the case you may want to by a new dw because not to many techs enjoy working on ASKO PRODUCTS or are they certified to do so. so it maybe difficult to get a service company to even look at it and if they do and the mtr is the issue you will be looking at a expensive repair. good luck
Jun 01, 2008 | Asko D1706 Built-in Dishwasher
Asko 1875 - will not stop
OK, just had the same problem wit my dishwasher, ASKO 1875, ,,,,,, Firstly, open the door and remove the tilt screws that secure it from tilting, top left and right corners at the front , pull the dishwasher out from under the bench enough so you can get to the back of the unit. Take care with the power cord [ should be turned off at the wall] . At the fear there is a panel at the bottom held on with 4 selftapping screws, remove these and ease panel away from the machine enough so you can see inside. Now you are likely to see alot of water sitting in the bottom tray, [ l did on mine } This exess water activates a small float under the pump which in my case caused the problem. Sponge the exess water out into a bucket, there will be quite a lot. Once dry try turning your dishwasher back on and hey presto the lights on the controll panel should be back to normal. Turn power off again, replace bottom panel to the back of the machine. Reinstall back under the bench, not forgetting to replace the tilt screws and all should work well....... Hope this helps. If still a problem you may have to dig into your wallet and call a serviceman. P.S. If you dont want to remove the back panel and sponge the water out, you can just tilt the dishwasher over to drain the water but this will cause abit of a mess {water } on the floor, but it is alot faster. Good luck.
May 25, 2008 | Dishwashers
Dishwashers Logo
145 people viewed this question
Top Dishwashers Experts
