Upc remote codes for hannspree tv - Televison & Video
5 Suggested Answers
  • 3230 Answers
SOURCE: Trying to put volume onto Sky remote handset from
Well you can please follow the below link to get you code -
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
Thanks for using FixYa!!
Good Luck!!
Posted on Mar 27, 2010
  • 5 Answers
SOURCE: can't get my hannspree remote to work with comcast
My Comcast Motorola STB's (Set Top Box) DCT 3412 / 6412 remotes did not support the new Hannspree 28" TV remote codes. Then I discovered the Hannspree TV remote was universal and had a button for Cable. Holding down the Cable buton I programmed in the Motorola VCR code 0050 and now my Hannspree remote controls the Comcast STB. Now I use the TV remote to control both Comcast Ste Top Box. PeterC
Posted on Jun 13, 2010
SOURCE: I have ATT u-verse remote, but I don't have code
I also had this problem. I talked to an AT&T technical support guy over the phone yesterday, and he told me some weird instructions. The TV was responsive to the controller but we couldn't get it to work. About an hour ago I called Hannspree technical support and they told me codes to control my AT&T receiver with their remote. I just tried the codes for my AT&T U-verse remote, just to see if they would work anyhow, AND THEY DID! Unfortunately, the codes will control the TV entirely, except turning it on.... (it does turn it off though) If these codes are of any use to you, they are: 1004 and 1018 try the first one, and if doesn't work, try the second one. If you are new to the AT&T U-verse world, these are the instructions: *Turn on your TV first 1)Hold the TV button on the AT&T remote 2)While holding, hold the OK button 3)Now release both of them 4)All the mode buttons while now flash twice (You will now have 6 seconds to do step 5, if not they will do a long flash, indicating to start over) 5)Now, quickly, type in the combination (in this case, 1004, or 1018) 6)The TV button will flash 3 times if it works, or a long flash if it doesn't 7)Now point the remote to the TV and press Power. If it turns off, IT WORKED! *Remember, these codes are the only codes I know of and they took forever to find, and they aren't supposed to work with the AT&T U-verse remote, but they did. The only defect is you can't turn ON the TV with the AT&T U-verse remote, but you can do everything else (YOU CAN TURN IT OFF)
Hope this helps!!!!
Posted on Nov 17, 2010
  • 18 Answers
SOURCE: 32 inch, hannspree tv.1080P I need
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Posted on Mar 15, 2011
Quantum fx tv remote control codes
0038,0031,0033. Try these codes. For more information http://electrohelponline.blogspot.com/
Nov 25, 2013 | Televison & Video
I am trying to find a remote code for the Cox 7820 remote, that will fully operate my Hannspree tv. The codes provided by Cox will operate most of the TV functions, on the correct buttons, all except for...
I have a Hannspree 42" LCD and I have the exact same problem, the code worked to control all functions except "Power On". I checked the Hannspree web site's support section, it says that their TVs will not work with a universal remote unless you have DirecTV. So why does everything work except to turn it on if they claim their TVs do not work with other remotes?
Oct 25, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Cannot program comcast remote to work with hannspree lcd tv 25"
try this
press tv button (lights up red)
hold setup button for 10 seconds (tv button blinks twice)
enter code 10030
Press power button on top right. If tv turns off your good
If it doesnt work follow steps above but try these other codes 11348, 11745, 11783
May 30, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
What is the remote control tv code for a Hannspree 28 inch tv using Verizon Fios? ljs
if you go to this online site you should be able to find your codes.
http://www.hannspree.com/us/common.aspx?mid=6172
May 15, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
I want to operate a upc remote control with a sky digibox. Does anyone know what code i use on the remote.
I have a tv set called meister ; can I have the code for setting my upc remote to controll the tv?
Apr 11, 2010 | Televison & Video
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Universal code for the hanspree
Please check here for information regarding Hannspree Universal Remote information. Basically, only the DirectTV Big Button remote has the Hannspree codes available.
Jun 03, 2008 | Hannspree (K206-10U1-005) Television
Hannspree 23 inch TV
You can use any RCA universal remote and then program per the users guide or use the website below to find the codes:
http://remotefinder.rca.com/default.aspx?site=rca
Hope this helps!
Apr 08, 2008 | RCA RCR450 Remote Control
Televison & Video Logo
281 people viewed this question
Top Televison & Video Experts
