Question about Motorola Cell Phones
I do not get any signal
Motorola fire xt xt530/xt531
    Scholar:
  • 140 Answers
Gday mate geoff here, just a thought, try plugging in the earphones to see if that gives it more aerial ,
Posted on Feb 11, 2012
Motorola service xt 1033
Motorola Company is best for purchasing mobiles, any mobile of motorola company gives you best service but here is the xt 1033 also gives best service it has gorilla protected glass that dont allow any scratch on mobiile and the service was very good in the cheap price
Sep 24, 2016 | Motorola Moto G Dual SIM - XT1033
Motorola Fire XT (XT530) charging problem .
Motorola FIRE XT Tips for extending battery life
Back to Previous Page
Are there any tips on how to extend the battery life?
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tips:
  • It may take several charging cycles for your battery to reach optimum performance.
  • The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
  • You can charge your phone via USB cable but this charging time will vary based on computer specifications.
Tips to extend battery life:
  • Select a shorter backlight duration
  • Lower the display brightness
  • Use the AC adapter to charge your phone whenever possible
  • Turn Bluetooth off when not in use
  • Turn Wi-Fi off when not in use
  • Close any third party applications running in the background
  • Playing music, videos and viewing images in your phone will affect your battery life
General Battery use & safety
  • Motorola recommends you always use Motorola-branded batteries and chargers. The warranty does not cover damage caused by non-Motorola batteries and/or chargers.
    Caution: Use of an unqualified battery or charger may present a risk of fire, explosion, leakage, or other hazard. Improper battery use, or use of a damaged battery, may result in a fire, explosion, or other hazard.
  • Your battery can be charged without it being fully depleted, and can be charged every day if desired.
  • Battery usage by children should be supervised.
  • Important: Motorola mobile devices are designed to work best with qualified batteries. If you see a message on your display such as Invalid Battery, Invalid Charger or Unable to Charge, take the following steps:
    • Remove the battery and inspect it to confirm that it bears a Motorola "Original Equipment" hologram;
    • If there is no hologram, the battery is not a qualified battery
    • If there is a hologram, replace the battery and retry charging it
    • If the message remains, contact a Motorola Authorized Service Center
  • New batteries or batteries stored for a long time may take more time to charge.
  • Charging precautions: When charging your battery, keep it near room temperature. Never expose batteries to temperatures below 0°C (32°F) or above 45°C (113°F) when charging. Always take your mobile device with you when you leave your vehicle
  • When storing your battery, keep it in a cool, dry place.
  • It is normal over time for battery life to decrease, and for the battery to exhibit shorter runtime between charges or require more frequent or longer charging times. Motorola batteries are designed to last between 350-700 charge/discharge cycles at room temperature. This amounts to approximately a year to a year and a half of battery use for most people.
  • Avoid damage to battery and mobile device. Do not disassemble, open, crush, bend, deform, puncture, shred, or submerge the battery or mobile device. Avoid dropping the battery or mobile device, especially on a hard surface. If your battery or mobile device has been subjected to such damage, take it to a local service center before using. Do not attempt to dry it with an appliance or heat source, such as a hair dryer or microwave oven.
  • Use care when handling a charged battery-particularly when placing it inside a pocket, purse, or other container with metal objects. Contact with metal objects (such as jewelry, keys, beaded chains) could complete an electrical circuit (short circuit), causing the battery to become very hot, which could cause damage or injury.
Apr 17, 2014 | Motorola Mobility XT530 Fire XT Black...
I don't have connection between the Thuraya phone and the FDU-XT
you can use The FDU-XT , because Thuraya XT can not use in the room , you can only receive the satellite signal outdoor . please see attached FDU-XT , Thuraya Docking station with outdoor antenna , which made by Huayang Technology , Brand Name : Matsutec.
www.huayang-tech.com
Jan 11, 2014 | Thuraya FDU- XT Fixed Docking Unit
Thin horizontal black line on lcd monitor
It sounds like the light has gone out at that point on the screen, you're going to have to replace the LCD monitor itself.
Feb 23, 2013 | Motorola Mobility XT530 Fire XT Black...
I need a Subsidy Unlock Code for my Motorola Cliq xt
To get Subsidy Unlock Code for Motorola Cliq XT try http://www.simpleunlocking.com/motorola-cliq-xt/rs16wp9/
You can get Subsidy code and step-by-step Instructions to unlock
Motorola Cliq XT from there.
Dec 07, 2012 | Motorola Mobility CLIQ XT (2 GB) Cell...
No storage space on telephone
You need to delete other message inbox.
Oct 21, 2012 | Cell Phones
How will connect internet in laptop by using mobile phone
You need to contact your cell phone provider for Internet connection details, there maybe additional cell phone data charges.
Aug 27, 2012 | Motorola Mobility Xt530 Fire Xt 5mp...
Hy my phone is moto cliq xt and ime is 358338032690325, please help me with the unlock code
you can get the unlock code for your Motorola model mobile phone, through this site http://www.wickedunlock.com/motorola/rs11wp8/
It has the best instructions and easy methods for unlocking your mobile phones.........
Nov 12, 2010 | Motorola Mobility CLIQ XT (2 GB) Cell...
Need a free unlock code for motorola cliq xt
This site supposedly has the steps and information about how to get your code.
http://hyfeno.com/unlock-motorola-cliq/
Find discount cell phones online.
Jul 10, 2010 | Motorola Mobility CLIQ XT (2 GB) Cell...
Cell Phones Logo
57 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
