Question about Whirlpool Washing Machines
Whirlpool AWO/D error code F2
Aqua-Steam 148 error code F2
dutchman05
  • 487 Answers
SOURCE: have just got new
Please register and forward this question to them
WHIRLPOOL
If this does not help you than Email direct whirlpool_customerexperience@whirlpool.com
If it is codes 32 it will be the pressure switch which is not working right
Posted on Jul 20, 2008
CMV9
  • 594 Answers
SOURCE: my model number
i can not find your model on the web page. you will need to contact whirlpool. www.whirlpool.com
Posted on Aug 22, 2008
  • 127 Answers
SOURCE: WHIRLPOOL 7MGHW9150PW0 will not drain has f2 and
I don't have access to those error code profiles at this time, but it appears its an over level condition on the water level switch circuit caused by a defective pressure switch or plugged connecting hose causing it to overfill, or you could have a leaking/defective inlet valve which will cause it to fill at all times sorta, or defective/clogged pump.
Or someone may have connected the drain hose of your unit directly to the sewer line without an air gap and somehow you are getting dirty"grey" water backing up into your washing machine.. ewwwwwwwwww!!
best of luck, and have fun,
ttfn
Posted on Feb 01, 2010
  • 27 Answers
SOURCE: whirlpool gb awo 3551 is not spinning of its
it cant work
Posted on Feb 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code washing is delayed wil wash half the clothes
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
My whirlpool awo/d 5556 washer displays error code f:26 can you help please?
F26 Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
The above information was take from UKWhitegoods web site
http://www.ukwhitegoods.co.uk/help/fault-codes/220-laundry-fault-codes?type=rss&limitstart=0
Feb 09, 2017 | Whirlpool Washing Machines
My brand new Whirlpool AWO/D 7740 shows error code f23 5 seconds after starting any program and won't do anything.
don't touch it
as it is still under warranty , call in a service technician for a warranty repair
Jan 28, 2016 | Whirlpool Washing Machines
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
Whirlpool aqua steam 6 door won't open tried resetting, cleaned out filter can you help ?
We had the same problem. Mechanic had to come and replace the lock. Took him less then three minutes to open the door, remove the old lock and put a new one in.
Jun 30, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
Error F6
Hi
Might a problem with the MCU [Motor Control Unit].
Try changing the Motor Control Unit and the wire harness to the motor.
Feb 29, 2012 | Whirlpool Dishwashers
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
My model number
Aug 19, 2008 | Washing Machines
Have just got new whirlpool aqua steam washing machine and it keeps stopping with the code f 23
F23 codes indicates an electronics communication problem with the washerThe following list of codes indicates an electronics communication problem with the washer. To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service
Jul 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
