I have an iSymphony LCiF80 LCD TV, when I cut the power on, no sound or picture, but the power/standby light indactes the it should be on.
24" 1080p LCD Television
    Problem Solver:
  • 5 Answers
YOU NEED A NEW HALOGEN OR WHAT EVER KIND IT TAKES. THE COMPARTMENT FOR THE BULB SHOULD BE ON THE REAR ELECTRIC PANEL MARKED BY FOUR SCREWS IN A SQUAR REMOVE THEM TO REVEAL BULB. THEN GO ONLINE TO MANUFACTURER AND ORDER NEW ONE
Posted on Feb 11, 2012
5 Suggested Answers
  • 10865 Answers
SOURCE: What universal remote code do
The reality is that almost everyone ends up using two remotes. One to turn the tv on and off plus adjust the volume plus the second remote to change channels within cablevision.
Call cable vision and complain. They could upgrade your remote if they chose to so u could do it all on one remote. Hope this explanation helps you. Joe
Posted on Oct 14, 2010
ladywinn
  • 5138 Answers
SOURCE: Dell W2600 26" LCD Television. My standby light is
If you can Solder and know what capaciotrs,resistors are you can ,or you can exchange out the boards. Look for Bad Capacitors on the Power Supply Board, this is the most common problem on these TVs 1000uf 16v 2200uf 10v 3300uf 10v they will be vented or puffed up on Top.
Posted on Dec 15, 2010
SOURCE: Samsung LN40B530 40" 1080p LCD HDTV Picture rotated
how to rotate my samsung flat screen monitor turning up side down
Posted on Jan 03, 2011
SOURCE: I would like to download user manual .pdf for iSymphony 40" 1080p HD TV Model# LC40iF80
I am giving you a link which contains two pdf files.
I hope you will accept it.
To go to link click here.
Thank you.
Posted on Dec 15, 2011
V is not working. when we press standby button to switch on 1 second on and have sound not have picture and go to off
It sounds to be a main power regulator board fault. Chekc and replace it. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 08, 2013 | Sony KLV32S550A 32 LCD TV
The tv wont come on the green light just keep flashing
Power supply needs to be first checked:
some information:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Jun 10, 2012 | Sharp LC52D85U 52 in. LCD TV
My rca lcd tv dvd combo power light came on but im getting no picture or sound
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_15_2012_1_22_51_pm.jpg
May 15, 2012 | RCA L32HD32D 32 in. LCD HDTV
Red light blinking
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_28_2012_3_29_51_pm.jpg
Apr 28, 2012 | Akai LCT2715 27 in. LCD Television
Lg lcd tv 42lc2db green light blinking 6 times then staying on but no sound and picture justa black screen
ISSUES:
Answers to issues:
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_3_2012_12_19_13_pm.jpg
Apr 03, 2012 | LG 42LC2D 42 in. LCD HDTV
ISymphony LC22iH90 22 LCD TV just black screen
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.4_3_2012_2_04_52_pm.jpg
Look inside at the power supply board to see if puffed up caps like these.
Apr 02, 2012 | iSymphony LC22iH90 22 LCD TV
KONKA KDL32AT23U 32 in LCD Television No back light, sound OK
Not likely it is the back light if you can eventually get it to come up.
Some general information (cap?):
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.3_29_2012_1_25_02_pm.jpg
Mar 29, 2012 | Televison & Video
I get only channel 2-14 on my TV. I have comcast with 200 channels and have 3 other tv with no problems on cable so it has to be I symphony TV
This can be due to that this TV does not have QAM tuner to get the free unscramble signals, this is the spec of the TV:
http://lcd-tv-info.blogspot.com/2011/01/isymphony-lc24ifh7pb-24-inch-1080p-lcd.html
You should look at the spec of the other TV to see if they are equip with QAM tuner.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Jun 23, 2011 | iSymphony LC24IFH7PB LCD TV
Red standby light flashing no picture or sound
the power supply is faulty, check the following
power trasistor
rectifier diodes
zener diodes
fusable resistors ( less than 20ohms)
and your set will work again
Apr 07, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Jan 06, 2008 | Bush 5693D 24" TV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
