IBM ThinkPad T20 2647 Notebook Logo
Posted on Feb 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I add a user or change my password - IBM ThinkPad T20 2647 Notebook
christop_bader
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 37 Answers
  • Posted on Feb 11, 2012
christop_bader
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
37
Questions
5
Helped
12773
Points
101
Go to the start button then click on "control panel" look for personalization and click that icon, on that page you will see ADD USER and CHANGE PASSWORD in the top left corner and go from there. you can also change your account picture the same way if you have one in your com;putor.
I want to add a new password because i cannot remember the old password
you didn't say what computer you are using, but unless you remember the password, and you have only the one account or user, you cannot add a new user. If you have access to the Administrator account, you can change the password.
tip
How to login to other people accounts using protected account
go start
go run
type cmd
type net users
you will see the user account on the command prompt
To change password
type net users "user name" *
type new password
type new password again
note when you change the password for the user you will not be able to see the password when you typing in the new password.
To add a new user
type net users "user name" /add
To delete user
type net users "user name" /delete
Can't get logged in on windows 8
Follow the steps:
Requirements:
1 ) Windows Vista or 7 DVD
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message "Press any key to boot from cd" appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer's startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
13.
At the welcome screen, logon using the local administrator account.
14. Access Control Panel then click User Accounts. Select the username of the account you can't login to then remove the password.
15. Log off on the current local administrator account your are logon to.
16. Check if you can logon to your user account now.
17. Open c:\windows\system32.
18. Right click on Magnify.exe, select Properties -> Security -> Advanced -> Owner -> Edit -> Administrators then click OK.
19. Select Edit -> Administrators -> Full Control then click Apply then OK.
20. Rename Magnify.old to Magnify.exe
21. Open command prompt then type the command then press Enter.
net user Administrator /active: no
To create a new user :
Net user username/add
Windows XP/2003, Vista and Windows 7.
To add a new user account to the local computer from command line:
net user username password /ADD
Example: To add a new user account with the loginid John and with password fadf24as
net user John fadf24as /ADD
To add a new user account to the domain:
>net user username password /ADD /DOMAIN
Note that we do not need to specify the domain name here.
Example:
net user John fadf24as /ADD /DOMAIN
Rename a user account from windows command line
We can use below wmic command to rename a user account from command line.
wmic useraccount where "name='username' " rename new_username
Ex: To rename the user account techblogger as win7techblogger
wmic useraccount where "name='techblogger' " rename win7techblogger
Net use command does not have any switches to rename a user account.
Few more Advanced uses of net user command.
To specify user full name while creating the user account
net user username userpasswd /ADD /FULLNAME:"User_Fullname"
To specify that the user is allowed to change the password
net user username userpasswd /ADD /PASSWORDCHG:Yes
To restrict user not to change the password:
net user username userpasswd /ADD /PASSWORDCHG:NO
To specify when the account expires we can use /EXPIRES switch.
To specify if the user must have a password set we can use /PASSWORDREQ switch.
How to create a new administrator account from command line?
An administrator account can't be created directly from command line. We first need to create a user account and then add the user to the administrators group.
Errors:
If you don't have privileges to add new user account to the system, you would get an error like below.C:\>net user John /add
System error 5 has occurred.
Access is denied.
C: \>
if cant able underatand send me your mail id..
Reset password compaq 615
Hey There,
Just go to control panel-all control panel items- user accounts
Then you will find 'Make changes to your user account'
And then you just click Add password/Add new password.
Thanks.
How do I remove log in username
for which operating system ????
Windows XP users
Change password
  1. Open Control Panel
  2. Double-click the Users Accounts icon
  3. Select the account you wish to change.
  4. Select the option "Change my name" to change your username or "Create a password" or "Change my password" to change your password.
Note: Windows XP Home users can only change the Administrator password through Safe Mode
Windows Vista and 7 users
Change password
  2. Click Add or remove user accounts.
  3. Click the account you wish to change.
  4. Click Change the password
Change username
  4. Click Change the account name
Windows 2000 users
Change password
Microsoft Windows 2000 users can change their username by pressing CTRL + ALT + DEL while in Windows to open the Windows Security window. From this window click the "Change Password" button
Enter your old password and the new password you wish to use.
Change username
In order to change the username of an account on Windows XP you will need to have an account with Administrator rights. If you're logged in as Administrator or have an account with Administrator rights, follow the below steps.
  2. Double-click the Users and Password icon
  3. Make sure "Users must enter a user and password to use this computer" is checked.
  4. Highlight the account you wish to change the username for and click the Properties button.
  5. Within the Properties you'll be able to change the User name.
hope this helps
How i change my user name and password
In windows XP open contol panel, then open User Accounts and click on the name of the user you want to change the name of. Then select change name and follow the on-screen instructions. Once the name is changed, you can click on "create password" and add a password for that user.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
1helpful
Changing password
goto control panel click it,.... goto Add or Remove user Accounts click it,...
drop down appears, asks for permission to continue or tells you you are not high enough on food chain --I have a vista operating program- ask for adminstrators password...
click... goto main User Accounts Page
click...change password
use a password that has at least six symbols,,,a capital letter,,,,some lower case letters,,some numbers,, adds up to six symbols ... ex.. Job226
I forgot my adminastor password
Elevate a secondary account outside of the admin account to admin status, then login as it and change your admin password. If you don't have a secondary user account, you can create one (and elevate it to admin status) by running the following from the command line:
net user "useraccount" "password" /add
net localgroup administrators "your pc's name"\"useraccount" /add
Of course, remove the quotations and insert the user account name, your pc's name, and the password where those words show up. That should allow you to get into Windows with admin privelages and change the administrator password. I do it through the "manage" function by right clicking on My Computer. Then go to Local Users and Groups, fo to the users folder, right click on your administrator account and hit "Set password". Hope this helps!
Dose any one know how to add security on N Modem Router
just type this no # 192.168.1.1 to internet explorer box and see the message box to type user and password this user name: user password: user or user name: admin password: admin Here in it you will find the option you need to change all need to change.good luck!
1helpful
2answers
Deleting and adding new users/passwords
try this: for IRC 3200 ,press asterisk with head press(near ?button)> ID SYSTEM setting> Dept ID management, you can add/delete Dept ID
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
