Question about Nikon COOLPIX S70 Digital Camera
Multi color circle lines on images
What is the solution if camera images show a multi color lines?
  • 890 Answers
I suggest that you perform a manual power resetting and check the operation.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Posted on Feb 11, 2012
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Funny ghost circles on image on long exposures zoom lens
Is there any way you could post one or more of these pictures so we can see it? From the verbal description alone it could be lens flare, caused by reflections from the internal surfaces of the lens. Without actually seeing it...
Jun 13, 2013 | Canon Cameras
Screen shows blurry vertical lines instead of image
It is failure of ccd imager chip in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
DC400 Screen only showing slanted multicolorlines
No this is clearly a CCD sensor problem ( CCD generates image in v-cams and still digital cameras ) if the sensor is outputting too much noise then your image will be distorted just like yours is. If the sensor is outputting nothing then camera shows blank screen ( also notice that with this problem you can playback OK ). Replace CCD block.
Sep 06, 2007 | Audiovox DC400 Camcorder
Redness in images
Yep, sounds like it might be a defective CCD imager. And if so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Jun 17, 2007 | Canon PowerShot A80 Digital Camera
What is the difference in metering among multi-segment, spot, and center-weighted?
Multi-segment metering uses 256 segments to measure luminance and color. This data is combined with distance information to calculate the camera exposure. This advanced metering system will accurate worry-free exposures in almost all situations including backlight condition. Spot metering uses a small circle area within the middle of image to calculate the exposure. The spot allows precise exposure measurements of a particular object without being influenced by extremely bright or dark areas within the scene. Center weighted measures light values over the entire image area with emphasis given in the central region. In backlight condition or when the subject is not in the center of image, exposure compensation will be required.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Nikon COOLPIX S70 Digital Camera Logo
199 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
