Question about Music
What is the DC polarity of the ca-ps800 AC/DV adapter ?
  • FOTO SPECIALISTAS Feb 11, 2012
    I have a CANON A420 camera and i must connect and supply it with an external 3V power supplyer (i made it myself) but i dont know where is the + and the - point on the input socket of the camera, to avoid damage. The original power adapter for this camera is the CA-PS800. So if you know the polarity of the DC jack of CA-PS800 , please tell it to me. Thanks...
2 Suggested Answers
  • 5603 Answers
SOURCE: My Casio WK-3800 will ONLY work on batteries not
Your adapter should be an AD12M. Some have tried a switching version of this and it has not worked. Make sure yours is the AD12M and not the "ML" suffix one.
The reason is that some of these have filtering built into the adapter, and others do not. The filtering is often required.
Posted on Oct 30, 2010
Adapter polarity
Boss ME-25, use polarity like boss stompbox.
+ voltage at the ring, and - voltage at the center pin, of the adapter
connector.
At ME-25 DC socket:
Sep 12, 2013 | Boss ME25 Guitar MultiEffects Pedal with...
The power on my banshee is coming on?
Check the polarity of the adapter, if it isn't the original one. Even if you have the right voltage, it still has to have the mA or higher but, most important is the polarity. Most guitar pedals are wired backward on the plug. The positive is on the outside ring of the plug and negative is in the middle. There should be a picture or diagram somewhere on the unit close to the plug to find out. If it is backwards, it could have damaged it, maybe not though. If it is ok, cut the plug off and switch the wires and check it. After all, it's not working now, it couldn't hurt.
Mar 15, 2013 | Rocktron Banshee Guitar Talk Box Talkbox...
Hi, I'm not sure of the polarity of the Lexicon mx200. I have bought a multi tip transformer & it gives 2 options of outside + or inside +, do you know which is which please, I don't want to fry it!...
DO NOT use universal adapters to run these devices. Accidents are too easy and often the universal devices do no have adequate filtering. You are off on the wrong foot to start with as this unit does NOT have a polarity since it REQUIRES an AC adpter, not a DC one. What you have WILL NOT WORK. If you have connected it, it should NOT have caused damage, you just won't get any audio out, even if the unit lights up on one polarity. The unit generates both polarities inside using the AC input.
Here is an example of correct adapter: http://lcdpayless.com/productpage.php?productId=5793
Apr 25, 2011 | Lexicon MX200 effects unit (with )
What polarity is the input on the ion IED04 DIGITAL DRUM STAION BY ION. I HAD TO GET A POWER ADAPTER AND DON'T WANT TO DAMAGE UNIT. THERE IS NO PICTURE TO NOTE POLARITY.
There is NO POLARITY to worry about since you MUST use an adapter that supplies 9 volts AC at around 850ma. You CANNOT use a DC adapter with this unit and have it work. Putting a DC adapter of 9 volts on it won't damage it, it just won't work.
AC output adapters are harder to find.
Apr 14, 2011 | ION Audio iED04 Desktop Electronic Drum...
Yamaha psr-280 flashing display no key response or sound. Is it dead??
Your adapter should be a 12 volt DC delivering 2 amps (2000 ma). If the adapter is too small, you will have the symptoms you are seeing. Make sure the polarity is correct. DO NOT use the so called "universal adapters".
Apr 13, 2011 | HQRP AC Adapter / Power Supply for Yamaha...
Need power cord for Casio CA-100 Tone Bank Keyboard
You need a 9 volt DC adapter with at least 850ms (0.85 amp) capabilty with the center the minus polarity. A good place to find thes is thrift shops, but DO be careful that the center is the MINUS polarity.
Jan 21, 2011 | Casio Music
I have Yamaha psr 260 and I am connect on 24V, and now speakers dont work. What am I doing?
I believe that is the wrong VOLTAGE !!!
The PSR takes a 12 volt, 1 amp or more DC power supply with positive on the pin.
If you have connected 24 volts either AC or DC of either polarity you have likely caused internal damage. Try a 12 volt DC supply and if it doesn't work, it needs to go to a repair facility.
ALWAYS check the voltage and the polarity on ANY of the devices using the power adapters BEFORE connecting the adapter..
Feb 18, 2010 | Yamaha Music
I have a Casiotone MT70 made in 1984. How do I check the polarity as I need to get an AC Adaptor and don't want to damage the keyboard?
Here is how you might check the polarity of a 7.5 volt DC replacement adapter:
Put the 5 batteries into the unit and verify operation. NOW using a DC voltmeter measure the voltage from battery negative and meter negative connected and meter positive to the pin on the power jack. IF you see 7.5 volts positive, then the pin is the positive lead for the adapter.
If you see zero, then continue testing.
With the 5 batteries inserted, connect the positive meter lead to the positive of the stack of batteries. Now touch the negative meter lead to the pin.
If there is 7.5 volts there, then the pin is the negative lead for the adapter.
READ THESE INSTRUCTIONS CAREFULLY.
USUALLY the jack has a contact that disconnects the batteery when the plug with sleeve is inserted.. We are testing the jack without inserting a plug here so the plug should HAVE THE BATTERY VOLTAGE with correct polarity on the pin.
Oct 07, 2009 | Casio Music
Casio keyboard doesn't work with ac adapter
Check the adapter is the right voltage AND polarity for the Casio... I believe they usually take a 9 volt DC adapter with the center pin being MINUS polarity.
Jul 14, 2009 | Music
Music Logo
37 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
