Question about Insignia Televison & Video
Can I change the font size for closed captioning on model no NS-LCD15-09 TV
    Master:
  • 879 Answers
To change the text size of close caption, you have to enter its service mode options. For more details, check this link by search to your TV model number
Posted on Jan 30, 2013
SOURCE: removing close caption on television
I was able to obtain a users manual online for free but I need to have a remote to remove the closed caption. Thanks for the response but I don't need to apply for an assistant plan.
Posted on May 26, 2008
  • 520 Answers
SOURCE: How do I get to closed captioning on the TV?
You will need the original remote. The TV/CAP/TEXT button turns it on and off. The CH.1/2 button switches between channel 1 and 2 of the closed captioning.
Posted on Dec 19, 2008
  • 106 Answers
SOURCE: How to remove closed caption from JVC TV without original remote
Try to get a univarsal remote a desent one at 15$ at walmart then try to use menu to, or unplug for 15 min then plug back in these should work.
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: can't shut off closed caption no remote
Have you tried unplugging the entire device and plug it back in 15 secs later.
Posted on May 17, 2009
SOURCE: I do not know how to turn off the closed
I have a Samsung 46 in TV. Here are my problems:
1. I do not have the remote that came with the tv.
2. I can't figure out how to get cc off the screen. I have a universal remote with no button for "cc". The directions mention to go into MENU, highlight SETUP menu, Highlight the PREFERENCES menu, then press the SELECT button, highlight the CAPTION menu, then press SELECT. The CAPTION menu appears. Then highlight the setting you wish to change. The Caption item in the Preferences menu alllows you to turn cc on and off.......
The problem is the universal remote does not allow you to use any Preferences menue or Caption menu.....
Suggestions???????????????????????????
Posted on Aug 13, 2009
I have a toshiba model 32L2400U. I want to increase the closed caption font size. How do I do that?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwi746HnuMjWAhWKs48KHU4PCMcQFggwMAI&url=http%3A%2F%2Fwww.tech-recipes.com%2Frx%2F46888%2Fios-increase-video-caption-and-subtitle-font-sizes%2F&usg=AFQjCNH5i-ItZjVmJeqpGmNOdxMBpFYucA
Sep 10, 2017 | Toshiba Computers & Internet
Closed caption font size
Size usually is not adjustable.
May 22, 2014 | ViewSonic NX2232w TV
Lg lcd subtitles are very tiny and i cannot read them..how could i enlarge them ?
Use ur tv remote.The remote have a button that said CC pushes that CC button a couples times for cycling more captioning-( Subtitles) words fonts display like CC 2,3.. the words should be bolder and bigger when it is going into with a different fonts setting.Or going the ur tv menu setting itself just change the close captioning fonts in different sizes or thickness and boldness.
Oct 24, 2011 | LG 42LC2D 42 in. LCD HDTV
How do I make the closed caption bigger. It has a black background and white letters that are too small. How do I fix it?
I suspect it depends on the TV. On my Viewsonic TV, I can select my CC font by choosing Menu > Option > Closed Caption. When the CC is set to On, go to Option and select Font Size.
On a Samsung TV, I use Menu > Setup > Caption. With the Caption set to on, then choose Digital Caption Option and Size.
Note if the captions are being provided by a set-top box, you may need to set the caption size on the box directly.
Please add a comment with your TV manufacturer and model; I'll try to find the specific directions for your TV.
I hope this helps.
Aug 12, 2011 | Televison & Video
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
How do I remove close caption wording on my tv screen??? (Insignia 42" TV don't know model number.)
Here is a manual for a 42" Insignia. Hopefully it's similar http://insigniaproducts.com/cms/documents/NS-42LCD%20UM%20EN_SP_FR.pdf
This one says the closed caption settings are in the "system setup" menu.
Feb 11, 2011 | Insignia LCDTV26 26 in. Television
There is a black box in the center of my tv
I would suspect your closed caption settings are set to text and there is no text available on the channel . I would figue out how to navigate the tv menu to cc or closed caption settings and set it to off. Sometimes there will be a cc.. or closed caption button on the tv remote to change those setting directly.
Jul 29, 2010 | Insignia NS-LCD19 19 in. LCD TV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
How to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
May 18, 2009 | Insignia NS-RTV32 32" TV
Televison & Video Logo
69 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
