Clean keyboard on laptop - Computers & Internet
  • 32,281 Answers
Use a vacuum cleaner to **** the dust from between the keys and use a damp cloth moistened with cleaning fluid to wipe the marks off the keys.
Posted on Feb 12, 2012
How I will clean my Laptop Keyboard.
Hi Shravan Chakravarty,
You may want to refer the below link to clean the laptop keyboard:
http://bit.ly/qCVqTs
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Nov 16, 2013 | Samsung Computers & Internet
Tip
How exactly to clean your laptop
Cleaning laptop case Cleaning the exterior portion of the laptop case can help keep the laptop looking new. The exterior case of a laptop can be cleaned by using a damp cotton cloth that has been dampened with water. It is not recommended that the exterior case of the laptop be cleaned with household cleaning solutions. However, if there is a substance on the laptop that cannot be cleaned with water, we suggest using rubbing alcohol.
Cleaning case openings
If dust, dirt, hair, or other substances are in the case openings, it can prevent air from getting into or out of the laptop. This can cause the overall heat of the laptop to increase, and in some cases may also cause such issues as random reboots.
Look for laptop openings where the laptop draws in cool air from outside or blows out any hot air from the inside of the laptop. These openings are usually on one of the sides, the back, or the bottom of the laptop. Dust, dirt, hair, or other substances can almost always be removed easily using a cotton swab and/or compressed air.
Warning: If you're using compressed air to clean the openings that have fans within them, it's possible that the amount of air blown on the fans can cause them to over spin, damaging or destroying the fan. To help prevent this issue, place something in-between the fan blades, such as a toothpick.
Cleaning laptop keyboard
Like almost everything else on a laptop, a keyboard is also different from the standard computer keyboard. With many laptop keyboards the keys cannot be completely removed. Therefore, we suggest cleaning the keyboard by using the same damp cloth you used to clean the exterior case of the laptop. In addition, compressed air can be used to spray any dust, dirt, or hair from in-between the keys.
If you've spilt something onto the laptop keyboard (like a soda) that's causing the keys to stick and cleaning it does not help we suggest that you have the laptop repaired since the keyboard cannot be replaced.
Cleaning laptop mouse (touchpad)
Cleaning the laptop touchpad can help improve the look of the laptop and also many times will help improve the responsiveness of the touchpad. To clean the touchpad surface, use the same damp cloth used to clean the exterior of the laptop.
Cleaning LCD display
Additional information about cleaning LCD and flat panel displays can be found on our main cleaning page.
Cleaning internal laptop components
Cleaning the inside of a laptop computer can be a difficult task. However, in some situations, it may be necessary because of excessive dust and/or dirt buildup within the computer, such as on the processor's heatsink.
Unfortunately, however, because of the complexity often involved in disassembling the laptop to reach many of these areas, Computer Hope cannot provide this information online for every laptop ever made. If you believe after cleaning your computer that it is still overheating because of dust and/or dirt buildup, we suggest taking the laptop to an authorized repair center.
Other cleaning information and help
Additional information and help with cleaning other portions of computers as well as discs and other computer related peripherals can be found on our main cleaning page.
on Feb 01, 2010 | Computers & Internet
I want to safely remove, clean and replace all keys on the Dell 610 keyboard
HI michael so if you want to clean your keyboard so first you must take off the keyboard from you laptop .
Let's remove the keyboard. Insert a flat head screwdriver between the keyboard bezel and laptop case and carefully lift up the bezel. Remove the bezel.
You'll find two screws securing the keyboard. Remove both screws.
Now carefully lift up the keyboard. You'll see the default memory module under the keyboard, right above the touch pad buttons. It's possible to replace the memory module without disconnecting the keyboard.
Disconnect the keyboard . Simply grab the blue tag attached to the keyboard connector and pull it up. Now you can remove the keyboard.
So now with removed keyboard you can clean it .
Jan 22, 2013 | Dell Latitude D610 Laptop Computer -...
Laptop keyboard problems
well , first of all you remove the cover and keyboard clean keyboard .the clean connectors. if don't have knowledge to how to remove and fix contact me I'll send you service manual. after cleaning it's not working you have to replace the keyboard
thank you
servicemanualboy@gmail.com
Jan 05, 2012 | HP Computers & Internet
I have recently cleaned my laptop keyboard with computer cleaning foam. Since I used it my keyboard has stopped working. I have left it over night in a warm place but still no joy. Any suggestions? Thanks
Did you remove the keyboard PRIOR to cleaning?
Would suggest you use an external keyboard, plug into your USB port and type away.
This would help identify if its just the keyboard.
Apr 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
Have a HP Pavillion 3163cl Entertainment Laptop and the Space Bar asks like someone is pressing down on it at all times. Like a stuck key and makes the noise when turning it on. The Laptop belongs to my...
To clean your laptop's keyboard you have to look under your laptop, you can see like keyboard icons with some scews, so, open them, they will let yout to remove your keyboard.
So now your can remove just your keyboard slowly for some connectors on the motherboard then clean it with a tooth brush.
You can only clean your keyboard with a toothbrush without rmoving it,
Try to remove the space bar key and clean under it.
Try to hard press the space bar for about 5 times, it can release the pusher under the key.
it some liquid was spilt on it you have to remove the keyboard and clean the plastic under ther keyboard.
Good luck
Jan 20, 2011 | Computers & Internet
Several keys are not working on toshiba L300
the problem is from the keyboard. Open the laptop, detach the keyboard from the laptop and clean it. If cleaning does not solve the problem, it means you will have to get another keyboard or use an external keyboard.
Take care.
May 29, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop keyboard not working
Usually in my experience most laptop keyboards are disposable. I have 2 suggestions for you.
1. buy a new same brand keyboard.
2. remove the flex connector, then use an external usb keyboard, or a bluetooth wireless keyboard.
hope it helps your problem.
Jan 03, 2018 | Acer TravelMate 5602WSMi Notebook
Coke spilled on to the keyboard for my laptop, but i still can turn it on and the mouse will work but the keyboard won't, i took off the keyboard to dry under it and put it back together but keyboard still...
Take it to the closest computer repair shop... And have them clean your laptop... Maybe the coke short circuited something on the board, and now it doesn't work ...
Mar 18, 2009 | Acer TravelMate 270XV Notebook
Laptop keyboard needs cleaning
I had a client with that problem--we removed the keyboard and tried to clean it. Turns out that our cleaning job was less than perfect because the laptop keyboard is mostly sealed. There was liquid that seeped down onto the motherboard as well--that we could clean up. The long and short of is--you will probably need to replace the keyboard. Of course, with nothing to lose, you could wash the keyboard and let it dry out thoroughly, plug it in, and see if it works. The key here would be the thorough drying. If you decide to try this chancy procedure, don't dry it with high heat. A hair dryer set on low might be the answer.
Feb 04, 2009 | Acer Aspire 3634WLMi Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
