Question about Maytag M6Y18F7A Air Conditioner
Noise when compressor kicks in
When the compressor is called for there is a period of loud chatter, like a motor starter chattering before the coil holds. After that it runs well. I have not yet taken this apart. It belongs to my neighbor and Maytag is giving her a bit of a run around, so she has asked me to help. It is still under warranty so I am reluctant to open it. I do have a background in applaince repair and industrial/commercial/residential wiring.
    New Friend:
  • 163 Answers
A leaking starting capacitor could cause this, but you got it, dont do nothing, the waranty could be void by you, claim it ...good luck
Posted on Aug 08, 2006
Gas valve on Vulcan oven SG4D-1 makes a chattering noise?
if it is a buzzing noise it is usually not big deal. If it is truly a chatter, I suggest replacing as the electric coil is going bad.
Jun 19, 2017 | Vulcan Ovens
Loud chatter on start and rattle from timing chain area
The timing chain area also takes in the alternator and water pump. To isolate the source of the noise, use the old mechanics trick.
Place a 3 foot 1/4 inch brass rod against the flap at the opening of your ear and push until it closes. Place the other end of the rod against various engine components and listen. The noisy problem will conduct the noise up the rod to your ear and you can hear quite precisely where the problem is. Much safer than laying your ear all over a running engine.
You can also loosen the fan belt and run the engine without alternator or water pump (briefly) to see how that affects the problem. Chatter on start makes me think of starter and Bendix gear problems. Sounds like a 2 person diagnostic team to me; one to start the car and one to listen and probe.
Don't know if Subaru Forrester has an engine that has valve interference at piston Top Dead Center. If it is and the timing chain breaks, you are looking at major $$ to recover.
Nov 06, 2012 | 2004 Subaru Forester
95 dodge neon, i just replaced the battery, and brain box (computer box) it started up then a few hours later tried it and now all it does is make a weird sound not a clicking like a starter would but a...
Darn, just sold my '95 neon. I never had to bother with the electronics, it always worked. That da da noise sounds like must come from some relay. Come to think of it, Chrysler makes had a kind of "main relay" called the Auto Shutdown Relay or ASD relay. It's purpose was as a main relay for sending power to necessary things to keep the engine running-like power to the ignition coil, and power to the fuel injectors, and to the fuel pump. This relay is triggered or controlled by the computer.
If you have a relay chattering and it is not a bad relay, then could also be a poor positive battery connection, or even a poor ground too. If that chattering sound is from the starter solenoid (on the starter motor), then you either have a weak battery or a poor connection ... or a bad solenoid.
Jun 08, 2017 | 1995 Dodge Neon
What does a BELT DRIVE CLIMATE COMPRESSOR do for a 528i bmw 1997
It has to be referring to the compressor for the air conditioner, but that is a very unusual name for it.
On a '97 318, there will often be a loud chatter when the compressor kicks on that is sometimes misdiagnosed as a failing compressor. In reality, most times it is the tensioner pulley on the belt.
Jun 27, 2011 | 1997 BMW 318
Loud fast clicking on and off
Relay chatter ,relay needs replaced coil cant hold contactors in. get to the noise, replace chattering relay.UNPLUG FIRST
Feb 18, 2011 | Harman Kardon AVR 25 MKII
When the refridgerator compressor turns on the fridge makes a loud chatter and slight ringing noise.
see if there is a fan in the back something could have been caught there
Sep 12, 2010 | Refrigerators
Ac makes loud chatter on acceleration been throuhg
hi, there is a published technical service bulletin about this problem for these vehicles and the tahoes. the compressor sitting so low in the system, gets over-run by the liquid freon banging internally and actually locks up on and off during operation. this is the noise you are hearing. apparently there is a screen kit to install in the low side suction line to prevent this from happening, but GM also states the compressor needs to be replaced and the new compressors from GM at least, already have this modification done. So, i replace them when they come into my bay with the complaint you speak of, and the tensioner for the belt, likely the belt too. but it looks like you already know all about that. hope i could help.
Jun 07, 2010 | 2001 Chevrolet Suburban
04 crf 250r.... the head has a chattering noise when running
Any chance the valve spring has collapsed? Cam shaft thrust washers missing? Cam shaft bearing gone bad?
abe5193.gif b3c3550.gif Please rate this solution. Thanks!
Jun 22, 2009 | 2005 Honda CRF 250 R
Kitchen range random chatter noise
could be clock motor or fan motor keeps running.
Jan 24, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Maytag M6Y18F7A Air Conditioner Logo
163 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
