Question about Smeg Ovens
Fitting heat element sa410x
Trying to remove faulty element and replace new one, unable to!! Service manual doesn't list instructions for remove and replace. It only has that for the door and door seal.
  • Smeg Master
  • 744 Answers
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Posted on Mar 06, 2014
4 Suggested Answers
  • 1462 Answers
SOURCE: Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Posted on Nov 29, 2008
barkencoa
  • 3463 Answers
SOURCE: do i ned instructions to fit new door seals i have the parts
See if you can lift the corner of the seal and see if there is a hook of some kind, if there is then all you do is unhook each corner, and remove seal, if no hooks, then it may be one of these tjhat is held in place by the the oven liner, and this is more of a tricky job to do.
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
  • 142 Answers
SOURCE: There's no heat from my
One quick test would be to turn on the bake and shake the element a little. Sometimes the connection burns loose and by shaking the element you may breefly make connection and there would be a little heat. If that does not work you would have to take the element out and check continuity. (Turn the power off!) Next you need to trace the wiring. If you have an old mechanical thermostat you could have a burnt terminal. I forgot, first make sure you have 240 Volt going to the oven. Fans, clocks, lights will work on 120 V. but elements need 240 V.
Posted on May 10, 2011
I have an Electrolux EW30EW65GS7 double wall oven and want to replace the baking element for the top oven. Is this done from the front or the back. I have the part and the oven is out and on the flo
Thank you for your post, Richard Gardner!
I understand that you need to replace the element inside of your Electrolux wall oven. I was unable to locate any specific step by step instructions on the removal and installation of your element. I have attached a copy of your parts manual and that provides a breakdown of all the available parts within your wall oven. If you need further assistance I would recommend having a professional technician out to properly remove the element and install the replacement part. I hope this information is helpful to some degree. -Matt
Jan 17, 2015 | Electrolux Ovens
SMEG OVEN BRAND NEW WON'T HEAT
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Sep 08, 2012 | Smeg Ovens
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven doesn't work (bake nor broiler) checked both heating elements there fine whats next?
With out a model number I was unable to look up any specific information.
First I would look for a thermo fuse on the back side. If you model has one it may be bad. If it's a older oven with a mechanical clock make sure the clock is not set to timed bake.
Aug 03, 2011 | Ovens
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Jun 13, 2011 | New World Ovens
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
Hi. My oven doesn't heat up after I've used oven pride on it. It's a New World DF 90 make. Everything else works, the fan, grill and hobs, but not the oven itself.
Unfortunately, it sounds like your heating element broke. Suggest using an ohm meter to make sure of that before you replace.
The good news is that element is pretty easy to replace and not very expensive either. Just make sure to trip the circuit breaker BEFORE you attempt the remove and replace.
Jun 05, 2011 | Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
I have a Thermodor SCD302ZP Double Convention Oven. Does the lower heating element come out from the front of oven or do you need to gain access to rear in order to test/replace it? I removed the...
that model number doesn't come up.first make sure the power is off to the machine,you have 240 volts going to that element,all the thermodor ovens i worked on come out from the front,there should be two phillips screws holding it in place,remove the screws and pull the element forwards,some of them you have to lift the element up the end that goes through the wall is bent up so the wires don't hit the metal wall behind it.on some the wires are very short so don't be surprised if they pop into the hole on you,try to hold it with a needle nose,have the other element in there and stick the wire right on the new element so you don't loose the wire into the hole,if that happens you might have to pull the oven and remove the back panel.good luck and i hope this helps you
May 11, 2011 | Ovens
Ovens Logo
101 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
