Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Replacement multi valve(micro switch) SUP 030 ADR
How can i find and order this piece which is broke?my service center told about this but they can not find it
    Problem Solver:
  • 5 Answers
There are 2 micro switches on the multi valve i have 4 spare ones if your interested markpittock@hotmail.com
Posted on Feb 11, 2013
I NID THE ONE MULTIVALVE SUP030 ADR.
Posted on Jan 20, 2015
I'm getting an error message when trying to print
Error 6C10 appears on certain Canon printers. It is a "valve cam sensor error". Here are some things to try to fix it:
Solution 1:
  • Move the printhead to the center.
  • Disconnect the printer and check on the right: is the purge unit ok? Is there a paper jam or piece of paper stuck in it?
Solution 2:
  • Do a reset of the printer by performing the following:
    • Turn the printer Power ON
    • Hold down the "Resume" button (triangle in a circle) for 15 to 20 seconds.
Solution 3:
  • Power off the printer.
  • Open the door.
  • Power on.
  • When the cartridge is in the center, close the door.
Solution 4:
  • Open the lid and allow the ink cartridge carrier to center itself.
  • Looking to the right, you will see a row of white rollers behind the carrier.
  • At the end of the rollers there is a small, clear piece of plastic that sticks up. Take a small piece of a paper towel and wipe all of the ink off this piece of plastic. When that is clean move on to the ink pad.
  • About 1 inch, towards the front of the printer from that piece of plastic, is a small square, about 1/2 inch per side, that is a small foam pad. This is where the excess ink is collected.
  • Take a piece of paper towel and press into the foam. Do this until the paper towel is no longer collecting ink. Close the lid, turn off the printer then turn it back on.
Solution 5:
Solution 6:
  • Remove case and look for the micro switch that is being pressed by one of the purge unit cams. Clean the switch and the cams. If the problem does not clear, replace the micro switch.
Aug 31, 2015 | Canon Office Equipment & Supplies
The little black piece that is on the connector that the keyboard ribbon connects to broke off. Can it be replaced? do you have the part?
You would have to replace the whole socket. If you are good at micro miniature soldering of multi-layer boards, you can attempt it. You may be able to buy a new socket and transfer the piece from the new socket to the old socket. As for parts, try your electronics supply house or, maybe ifixit.com.
Mar 09, 2015 | HP Pavilion Sleekbook 15-b142dx 15.6...
The little rectangle piece on the back of lid
Hi Theresa. I'm sorry you're experiencing difficulty with the rectangular piece that broke off on your ProHeat 2X.
Gluing the part may interfere with the suction on your machine. I'd recommend replacing the tank lid.
Here's a link to order: http://www.bissell.com/service-centers/? cid=ccsocial&cid=ccsocial
Aug 20, 2013 | Bissell 9200 Upright Vacuum
Center unit light keeps flashing when put in the right spot
If you are 100% sure that the Brew unit is installed properly then you may have a broken micro switch.
You would need to remove the top cover of the machine to replace the switch or you would have to bring it to a service center.
Call the number at the top of this website to order the switch if you determine it is the issue.
http://www.CeriniCoffee.com
May 30, 2011 | Saeco Magic De Luxe Espresso Machine
Motor does not shut off when trigger on wand is released
When the trigger is released, pressure builds up and this acts on a valve (spill valve or pressure control valve). When this pressure is big enough it will push the spill valve out and closes a micro switch. Now this Spill Valve gets stuck sometimes, mainly due to soap and chemicals...so the micro switch is not closed...so the machine contiues running. If this is left likee this it will cause damage to the valves. So all one has to do is service the spill valve or as I usually do I replace it. There are cases were the micro switch is damaged also..and needs to be replaced. To see the spill valve and micro switch you must open the cover. The spill valve is located where you see a cover with an electric wire coming out of it. If the micro switch is good...you must tackle the Spill valve.
Regards,
fulltech.
Jul 17, 2010 | Karcher PSI Electric Pressure Washer
Replace poulan 2150 chainsaw prime bulb
You can use this site to find a Poulan service center or order parts:
http://www.poulan.com/
May 30, 2010 | Garden
Problems with Aroma ARC-930 20-Cup Rice
You can order parts at www.aromaco.com, if the part is not available online you may contact their customer service department at 1-800-276-6286 Monday-Friday 8:30am-4:30 PST.
I broke mine, so I had to order a replacement. I couldn't fine the part online, but they do have it if you call them.
Sep 08, 2009 | Aroma ARC-930 20-Cup Rice Cooker
Insert Drip Tray
Check the right side of the tray holder. There should be a small lever (micro-switch) that you can feel and press in. If it does not click when pressed then you need to replace it at a service center. If the leaver just broke off (a small triangle piece with a tab on the end) then you may be able to stick a piece of card board to make the switch click and fool the machine to think the tray is in. until you can get it to a service center. ukeboy@pixi.com
Dec 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
No paper fed
I'm guessing that little piece of plastic has something to do with the paper sensor.  You may want to open that section and set it back the way it was.
Oct 27, 2007 | Brother Multi-Function Center MFC-240C...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
346 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
