Question about Air Tools & Compressors
Fuel problem I have a 1998 dodge Caravan and for some reason after the van runs for about five minutes the fuel line is blowed off the connection point where it goes to feed the fuel rails underneath the car. I just installed a new fuel filter to make sure it was not bad but did not help.
  • b762mmfmj Mar 13, 2010
    I just recently did did two dodge van and the problem is the fuel pressure regulator is going bad in the tank. What happens is the pump puts out more pressure then the system needs so the regulator opens and closes to keep correct fuel pressure.You are having a intermitant proble and the pressure regulator is not opening and blowing the supply line off.
    What I suggest you do is go to autozone, advanced auto or equiv and get a complete fuel sending unit which consists of pump,regulator and fuel indicator I just priced one they are about 160.00 dollars. BUT WHATEVER YOU DO DO NOT JUST BUY THE REGULATOR IT IS 90.00 DOLLARS ALONE AND THAT NEW REGULATOR PUTS PRESSURE ON OLD PUMP AND WHAMO YOUR FUEL PUMP GOEW BAD trust me I learned from experience
  • 65 Answers
Check your fuel return line back to the tank that it isnt blocked or kinked
Posted on Dec 03, 2008
Location of fuel pressure regulator on 2006 dodge caravan 3.3
Replace fuel pump and filter that is not a regulator problem.
Bad fuel regulator will cause vehicle to surge at cruise speed or they leak and cause engine to suck excessive fuel into intake if vacuum control then blows black smoke.
Jan 24, 2015 | Dodge Cars & Trucks
2003 dodge van runs ok one day and dies out the next
check the cat converter for failure as it breaks down and causes a blockage in the exhaust. t may have been the reason for the muffler failure by not burning off the unburnt fuel in the first place.
Jul 27, 2013 | 2003 Dodge Grand Caravan - All Grand...
Poor gas mileage on my 1993 dodge caravan
If you want fuel economy then dump this beast and buy a nice peugeot or citreon picasso diesel manual then you will get around 30 mpg around town and anything up to 70 mpg on a run ,try paying our fuel prices and this nice typical american petrol gas burner would be delegated to the classic car sunday drive out like my jag with its 4lt engine i can only afford to take it out once a month or so on a jaguar club run around ,other than that its my ford diesel manual escort with its 0 to 60 in 15 minutes but it only uses one tank of fuel a month.
May 11, 2012 | 1993 Dodge Caravan
1988 Dodge caravan SE. Metal fuel line coming from gas tank to the drivers side rear. what does it connect to? Not talking about the fuel line going to the fuel filter. It fell of and cant find what it...
Sounds like you have a broken fuel return line. The high pressure line goes through the filter and to the injection system, and the unused fuel is returned through the pressure regulator back to the fuel tank.
Jul 01, 2011 | 1988 Dodge Caravan
1998 Dodge Caravan. engine dies and wont start. fuel pump was changed twice but i get a few miles & dies again & wont start. im thinkin fuel filter is plugged....
It might be your fuel filter. Also, Dodge and Chrysler is bad for fuel pump failures. A clogged fuel filter can cause this. Also, you might not be getting enough fuel pressure. There should be a test port on the van, where you can test the gas pressure. You also have a fuel pump relay or switch. This could be bad as well. Hope this helps you.
Jan 08, 2011 | 1998 Dodge Caravan
Where is the fuel filter located on 2005 dodge caravan
It should be found next to the gas tank on the right side, under the sliding door of the passenger side of the van. The fuel filter is cylindrical and about five inches
May 21, 2010 | 2005 Dodge Caravan
Dodge Grand Caravan line from fuel filter to engine connection is too short. Checked three other filters and have same length. Are we installing it wrong?
Are you using a purolator fuel filter?
They are excellent filters BUT have fitment problems on more than vehicle
Get the Dodge brand fuel filter and see if it works, if it doesn't you can always return it.
Double check that the fuel line is correct for your year model van it could be the wrong one.
Filters usually have an arrow stamped on them showing which direction to install it.
Mar 31, 2010 | 1999 Dodge Grand Caravan
I have a 1996 dodge caravan that gives off raw gas fumes when its real cold out side, the fumes come in the front liie from the engine area throught the vents and when I park it in the garage its real...
this sounds like you have a bad fuel line (leaking) clean the engine compartment let dry then let the van run. follow all your fuel lines from the engine back and you will find the leak. you will have a fuel pressure line and a return line back to the tank
Jan 02, 2010 | 1996 Dodge Caravan
Air Tools & Compressors Logo
105 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
