When I use the wi-fi connection with the LAN cable provided and run the connection test, all of the tests are successful except for the Viera connection. It is saying the connection failed 006.
All connections to this tv - Wi-Fi, Blu-Ray, HDMI cables,LAN cable, Theater and Sattelite are all working fine. The Viera connection link is showing the error 006 and is not allowing me to see the Viera connection options, ie. youtube, market,skype,etc.
  • 19 Answers
SOURCE: 42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Posted on Feb 21, 2009
milkburp
  • 416 Answers
SOURCE: i have a samsung tv and samsung blu ray i have my
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Posted on Apr 07, 2010
  • 9 Answers
SOURCE: my 50 inch panasonic viera tv seems like it is
This set will do 1080P. If your external devices are set properly the set should automatically switch to there mode. Try chaning which inputs you are using, trying one device at a time. Use HDMI for you Blu-Ray and either HDMI or component for your Direct TV. Chek your setting for putput on both of these to make sure of your highest quality video. 1080P on the Blu-Ray 720P on the Direct( yes 720p is higher than 1080i).
If this does not reslove try doing a reset on youset.
Press and hold volume down on your TV and the menu button on the remote. The set runs a self check then displays the results. when finished unplug the set for about 30 seconds. when you plug the set back in and turn it on it will come up in the original set up mode. youe will have to reprogram your input setting channel scan ect. so try the other things first. I hope this helps.
Posted on Apr 29, 2010
SOURCE: How can i search something
Place the cursor in the Select field and then press the select button; this will bring bring up a keypad on the screen which you can work with the navigator or the remote keypad (like a mobile phone)
Posted on Jan 08, 2011
SOURCE: Panasonic Viera Link stop working
Hey, you're not the only one to have this problem. Please see also
http://www.fixya.com/support/t5668469-viera_link_stopped_working_stating
Hope someone can help us all!
Posted on Jan 25, 2011
No Internet can I connect to my neighbours so I can watch Netflix on my play station
Hello Friends,
First of all you are self connect to internet, there are two options you are connect internet.
1> Wi-fi through you connect and Lan cable. connection before you configure Internet IP address, DNS to you laptop, and open wi-fi option. and sec option is cat5 and cat 6 wire through connect.
But all thing available you have like RJ 45 connector, Lan tested, Lan cable, cutter, etc.
My suggestion you contact networking engineer because have all network thing available.
More Technical Support visit and call.
Aug 25, 2013 | Computers & Internet
When I use the wi-fi connection with the LAN cable provided and run the connection test, all of the tests are successful except for the Viera connection. It is saying the connection failed 006. How do I...
Viera has a set-top box in the TV and the lan wifi router can be connected to cable plant for internet. TV can also send out programs on the set-top box to other wifi receivers. Error code 006 is server failed, Panasonic had a fix on jan11, 2012.
Feb 11, 2012 | Computers & Internet
How to get wifi of my ds lite
With an online-capable game insertedinto your Nintendo DS, turn on your system and access the game's main menu. Access the Nintendo Wi-Fi Connection settings.(These settings are typically found by selecting "Nintendo WFC" fromthe game's main menu. For detailed directions, consult the manual for thegame.) At the Setup screen, tap"Nintendo Wi-Fi Connection Settings." Tap "Connection 1 None." Clickon "Search for an Access Point." TheNintendo DS will search for any wireless networks within range. Once it isfinished searching, it will display the names of all the wireless networks itfinds. Look for your wireless network. What to do next will depend on the"lock" icon you see next to your network on the Nintendo DS. If thelock icon that appears is unlocked and blue, Select "OK," "SaveSettings," and then "Yes." The Nintendo DS will run a connectiontest with your wireless router. The connection test was successful - YourNintendo DS is now connected online and you can enjoy the Nintendo Wi-FiConnection features of the game! The connection test was not successful - Ifthe test was not successful, you will receive an error code. Error Code 51300: This means the security codeor network name entered into the Nintendo DS is not the same one the router isset to. To reach your connection settings, click "back" on the errorcode screen. Make sure to pay extra attention to the security key you find inyour router's settings and enter it exactly as it appears (the key is casesensitive). For all other error codes, go to the Nintendo website or contactcustomer support. If the lock icon is locked and red, Enter your router's WEP keyinto the Nintendo DS Select"OK," "Save Settings," and then "Yes." TheNintendo DS will run a connection test with your wireless router. Theconnection test was successful - Your Nintendo DS is now connected online andyou can enjoy the Nintendo Wi-Fi Connection features of the game! Theconnection test was not successful - If the test was not successful, you willreceive an error code. If the lock icon is locked and grey, and you wouldstill like to connect your Nintendo DS online, you will need to either changeyour router's security to WEP, or disable security entirely. Please note thatany changes you make will affect other devices that connect wirelessly to yourrouter.
Sep 17, 2011 | Video Game Consoles & Games
How to set up wifi
Sep 17, 2011 | Nintendo Video Game Consoles & Games
How to enter the internet
Sep 11, 2011 | Nintendo DSi White Console
How to put internet on my dsi
Sep 11, 2011 | Nintendo DSi Black Console
How do I connect to the internet
Sep 05, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
How do i get internet
Sep 05, 2011 | Nintendo DSi Blue Console
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
Jul 05, 2011 | Nintendo Video Game Consoles & Games
My sony vaio e series can't connect to the
Hi
You need to make some tests first,
Try to get LAN cable form other PC at home, and plug it in the sony vaio
You need to enable wireless ( Through wi fi switch, of Fn + F2 )
Please tell us your results
Good Luck
May 13, 2011 | Sony Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
