When I use the wi-fi connection with the LAN cable provided and run the connection test, all of the tests are successful except for the Viera connection. It is saying the connection failed 006. How do I fix this
  • Dave Ra. Feb 11, 2012
    This is a problem with my tv- Panasonic Viera TC-P60ST30 not a laptop. The internet wi-fi connection is fine. The issue is that the Viera link connection is not working. How do I fix this. The HDMI cables and LAN cable are properly connected. The Blu Ray and all other connections are working.
  • 734 Answers
Viera has a set-top box in the TV and the lan wifi router can be connected to cable plant for internet. TV can also send out programs on the set-top box to other wifi receivers. Error code 006 is server failed, Panasonic had a fix on jan11, 2012.
Posted on Feb 11, 2012
  • 277 Answers
SOURCE: wi fi internet not working
make sure you have loaded the aria networks driver
Posted on Mar 30, 2009
Geekman
  • 32281 Answers
SOURCE: Wi-Fi and Lan Network is not working, drivers required.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still type in the Service Tag number, it is printed on the label on the bottom of the laptop. Also make sure you select the Windows XP version of the driver for your Windows operating system.
Click on this link :-
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on Apr 05, 2009
SOURCE: I have a problem witch wi-fi. my wi-fi can'not
here is the download link for your Wi-Fi driver
For Windows Vista :
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_wifi_realtek_28824A.exe
For Windows 7 :
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_wifi_atheros_TC00190600E.exe
Download and install the driver according to your operating system.
Your Wi-Fi will work fine now.
That's it.
Posted on Jan 24, 2010
  • 857 Answers
SOURCE: lan card driver and wi fi driver sd card driver
depending upon the manufacturer of the laptop you can go to their websites, from their you can select drivers and downloads and then select the model no of your laptop and then download the drivers you need.
If you have any further problems please reply with the model no of your laptop and i will send you the link.
Posted on Mar 11, 2010
  • 825 Answers
SOURCE: I have a compaq presario F756nr with an Atheros
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Posted on Mar 29, 2010
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
No Internet can I connect to my neighbours so I can watch Netflix on my play station
Hello Friends,
First of all you are self connect to internet, there are two options you are connect internet.
1> Wi-fi through you connect and Lan cable. connection before you configure Internet IP address, DNS to you laptop, and open wi-fi option. and sec option is cat5 and cat 6 wire through connect.
But all thing available you have like RJ 45 connector, Lan tested, Lan cable, cutter, etc.
My suggestion you contact networking engineer because have all network thing available.
More Technical Support visit and call.
Aug 25, 2013 | Computers & Internet
How to get wifi of my ds lite
With an online-capable game insertedinto your Nintendo DS, turn on your system and access the game's main menu. Access the Nintendo Wi-Fi Connection settings.(These settings are typically found by selecting "Nintendo WFC" fromthe game's main menu. For detailed directions, consult the manual for thegame.) At the Setup screen, tap"Nintendo Wi-Fi Connection Settings." Tap "Connection 1 None." Clickon "Search for an Access Point." TheNintendo DS will search for any wireless networks within range. Once it isfinished searching, it will display the names of all the wireless networks itfinds. Look for your wireless network. What to do next will depend on the"lock" icon you see next to your network on the Nintendo DS. If thelock icon that appears is unlocked and blue, Select "OK," "SaveSettings," and then "Yes." The Nintendo DS will run a connectiontest with your wireless router. The connection test was successful - YourNintendo DS is now connected online and you can enjoy the Nintendo Wi-FiConnection features of the game! The connection test was not successful - Ifthe test was not successful, you will receive an error code. Error Code 51300: This means the security codeor network name entered into the Nintendo DS is not the same one the router isset to. To reach your connection settings, click "back" on the errorcode screen. Make sure to pay extra attention to the security key you find inyour router's settings and enter it exactly as it appears (the key is casesensitive). For all other error codes, go to the Nintendo website or contactcustomer support. If the lock icon is locked and red, Enter your router's WEP keyinto the Nintendo DS Select"OK," "Save Settings," and then "Yes." TheNintendo DS will run a connection test with your wireless router. Theconnection test was successful - Your Nintendo DS is now connected online andyou can enjoy the Nintendo Wi-Fi Connection features of the game! Theconnection test was not successful - If the test was not successful, you willreceive an error code. If the lock icon is locked and grey, and you wouldstill like to connect your Nintendo DS online, you will need to either changeyour router's security to WEP, or disable security entirely. Please note thatany changes you make will affect other devices that connect wirelessly to yourrouter.
Sep 17, 2011 | Video Game Consoles & Games
How to set up wifi
Sep 17, 2011 | Nintendo Video Game Consoles & Games
How to enter the internet
Sep 11, 2011 | Nintendo DSi White Console
How to put internet on my dsi
Sep 11, 2011 | Nintendo DSi Black Console
How do I connect to the internet
Sep 05, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
How do i get internet
Sep 05, 2011 | Nintendo DSi Blue Console
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
Jul 05, 2011 | Nintendo Video Game Consoles & Games
My sony vaio e series can't connect to the
Hi
You need to make some tests first,
Try to get LAN cable form other PC at home, and plug it in the sony vaio
You need to enable wireless ( Through wi fi switch, of Fn + F2 )
Please tell us your results
Good Luck
May 13, 2011 | Sony Computers & Internet
Computers & Internet Logo
314 people viewed this question
David Payne
David Payne
