Question about Ricoh 3310LE Copier
AR-157E Had the ribbon cable on the scanner crimp and jam the copier. Straightened out the cable but unable to reset the L 1 codes and get the machine working. How can I reset the trouble codes? Thanks, John
  • 2 more comments
  • detjas Oct 24, 2008
    Sorry, yes it's a Sharp AR-157E copier.
    Thanks, John
    Thanks, would you know the part number for the cable and if there is a place to purchase it?
    Thanks again, John
  • detjas Oct 25, 2008
    OK, went to their site and ordered it. Thanks again, John
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this for a Sharp Machine?
  • Ricoh Master
  • 2,794 Answers
Take some scotch tape to the cable and secure it.  If the cable is too messed up and you still get the error code, you may need a new cable.
There is no reset code for an L1.
Posted on Oct 24, 2008
  • Tim Babcock
    Tim Babcock Oct 25, 2008
    I don't know the part number for that cable for that particular model.   Check with precision roller.  They have the part for you.
Sharp 157e H4 blinking,where is the fuse and or thermostat to check. This Church copier is 6 years old and paying a technician several hundred dollars to come out to fix it is crazy. Do you have any...
Push the 'clear' button and then the 'auto' button then the 'clear' button and then the 'auto' button again.This should be done as quickly as you can and the console will go blank.Next,select 14,which is the low temp clearing code, and then push 'start' and then turn the machine off and back on again.
Aug 09, 2011 | Sharp AR-157E Copier
Unable to copy code h5 01
Cause: Paper jam in fuser unit or paper jam removed beyond required time.
solution: remove jam from fuser unit.....perform simulation 14 to reset machine!!!
Feb 23, 2011 | Sharp AR-407 Copier
Flashes L 4. Copier does not respond to any effort to get to go beyond L 4
L4 = Main motor lock When the main motor encoder pulse is not detected for 100 msec.
hi Valerio
Sep 06, 2010 | Sharp AR-157E Copier
Sharp AR-157E unable to copy
Hello sir; Check the scaner unit, when you make copy does mirrow move out and return to home if not check the mirrow motor or cable.
May 28, 2009 | Sharp Office Equipment & Supplies
Can you bypass a low toner alarm on a AR 157E to allow the unit to run paper through the paper path
Yes in service mode. But you will not make a copy with out any toner in the copier.....
May 06, 2009 | Sharp AR-157E Copier
AR-157E blank page when using automatic feeder.
you night check to see if your cable to the copier is connected but this problen iv seen several times not worth fixing the main pcb is usally gone as for as working with the feedder
Feb 17, 2009 | Sharp AR-157E Copier
L-1 error code.
Turn the copier off and remove the scanner glass. Sometimes the ribbon cable underneath the scanner gets bound up on the scanner. Flatten it out and secure it with scotch tape. make sure that the loop has enough slack on it for the scanner to travel freely.
Oct 06, 2008 | Sharp AR-153E Copier
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
Sharp ar5127 copia eror slution
Check the scanner lock located under the scanner section on the left side. Change the position of it.
If it sitll locks the scanner could be jammed up by the cable. The scanner glass has to be removed to fix that.
Jun 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Ricoh 3310LE Copier Logo
88 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
