Question about LG 42LE5400 42 in. LCD TV
Do you supply instructions to operate LG 42LE4500 television?
My husband has lost our copy of instructions to operate. Is there a possibility we can procure another copy?
  • J.McNeil Feb 12, 2012
    Thank you ronpauljohn - I was really surprised to receive an answer so quickly. Shall endeavour to do as instructed.
2 Suggested Answers
LG 42LE4500 ZA no picture
1 or 2 condensed broken check it better in YouTube can see better with images
Dec 30, 2015 | LG Televison & Video
Lost operating instructions, need to program. Are there on line instructions that i can download?
1) Copy following link to identify timer, and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
2) Add comment and include photo or detailed description of timer for possible identification of timer, and possible manual
Dec 04, 2012 | Hardware & Accessories
Lg 42le4500 tv when first turned on its okey after 2 minutes no picture black screen but sound ok, turn it off and back on againdoes the same
I would bet on some component(s) have become thermo sensitive. Most of the time capacitors can do this type of thing. Most likely the defective caps could be in the power supply.
To locate the defective caps, you would have to be able to run the supply and use the combination of a heat gun and freeze spray (liquid air spray) for cooling. At the same time you would have to monitor the output of the supply to see the components that cause the output change.
It is also possible to have thermo sensitive components on any of the other boards. This would also require proper troubleshooting.
The service rep would replace boards until he found the defective board. Then he would return the set with the new board and the bill for his work.
If your set is out of warranty, it may be better to consider a new set. Servicing these can be fairly involved and expensive.
Jerry G.
Jun 25, 2012 | LG Televison & Video
I bought a lg 42le4500 led/lcd tv and hooked it up to my v+ box via a hdmi lead, but picture is a bit fuzzy is there somthink i can do to sort this?
Check the setting on the V+box for a HD setting hook up should improve the picture.Still have the same problems,the HDMI cable it is the problems,changes another HDMI cable
May 10, 2011 | LG 42LE5400 42 in. LCD TV
Techno-phobe requires operators manual/instructions for 32" LG5700-ZF
If you were to log on to lg.com web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
The information is normally free of charge.
I hope this helps.
Jan 18, 2011 | LG Televison & Video
Please could u help ime looking for a manual for a LG 42LE4500 LED TV Thanks
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Jan 02, 2011 | Televison & Video
Just bought a 42LE4500 model. Picture looks blury during fast movement. It appears the system is not processing the picture in time.
This model has just a 50Hz refresh rate and so this is a known problem. Try and view it from the recommended distance of 3 times the TV diagonal width ; the effect of this problem will be vastly lessened.
Nov 27, 2010 | LG 42LE5400 42 in. LCD TV
LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
LG BG8000ER Air Conditioner Problem!!
go to ca.lgservice.com find find owner's manuals under quick links and then fill in your product information to obtain a copy of the instruction manual.
Jul 31, 2007 | LG BG8000ER Air Conditioner
LG 42LE5400 42 in. LCD TV Logo
81 people viewed this question
Computer Repairing
Computer Repairing
