Question about Kenmore Freezers
Kenmore 253.28712809 freezer will not turn on
The display shows 'off', pressing the down arrow has no effect.
jyackle5
  • 8197 Answers
SOURCE: 253-21421104 Kenmore Freezer What is the
Your freezer is 20.3 cu.ft.
Good Luck
Posted on Aug 29, 2010
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
larryyb
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
Controlfrk
  • 304 Answers
SOURCE: Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
Posted on Sep 17, 2009
Sea Breeze
  • 4654 Answers
SOURCE: need a manual for 253-9284215
The first three number are who made your refrigerator, Gibson (Frigidaire) Below are the model numbers that the user manual falls under, Click Here=> 253.9284215
KENMORE Upright Freezer Model: 25321711103, 216769200, 25321402101, 25321741102, 25329201002, 25321402102, 2539280415, 2539287215, 25321041100, 25321201102, 2539280214, 25321411100, 25321211101, 25321421104, 2539284215, 25320211002, 25321111103, 25321421101 If you have questions please let me know, Thanks, Sea Breeze
Posted on Oct 06, 2010
How do i get my Kenmore Elite freezer out of demo mode
Which model freezer do you have?
A few possible resets: press and hold the Set and + keys for 5+ seconds. On some models, that will get the freezer out of demo mode. On other models, it's the Set and Down arrow. For a few models, it's the Options and Up arrow. In all cases, it's press and hold both buttons until the unit responds.
I hope you will add a comment with the model of your freezer so that I can determine which set of instructions will work for your unit.
Sep 29, 2015 | Kenmore Freezers
Let's try this again. My frigidaire freezer model Lffh21f7hwg, the display board reads "of". How do I reset it. I do not have the owners manual.
I appreciate your post, Clayton!
From the information you have provided the display board on your Frigidaire freezer reads "OF". That reading means your freezer is off, you should be able to turn it back on by pressing the up or down arrow five times in a row. If you need any additional assistance please feel free to reconnect. I hope this is helpful to you. -Matt
Mar 31, 2015 | Frigidaire Freezers
Why is my freezer on 0?
Good Afternoon Friend, this is Z. That's a great question!
Depending on the model number of your Frigidaire freezer, "0" could indicate two scenarios. First, if it is set to 0 (zero) that could be the temperature it is set at. On some models, "0" means that your freezer is in the off position. You can re-start your freezer by pressing and releasing the "UP" arrow 3 times. If it continues to display "0", press and release the "DOWN" arrow 3 times. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has change successfully. Thank you!
Jul 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
STOPPED RUNNING
Hello Warner, thank you for your post!
Typically when a freezer displays "OFF" it means that the temperature control is in the off position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try re-activating your freezer by pressing the UP arrow until display shows "4" or desired setting. If the issue persists, then the freezer could possibly be experiencing a communication issue with the control board, temperature control or a potential wiring failure. At this point, I suggest reaching out to an appliance expert who is best equipped to pinpoint the exact problem.
Best of luck!
Feb 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire
If it is showing "OFF" then the unit is in demo mode. To remove this press the up or down arrow three times as fast as possible (within 2 seconds). This will start the compressor. I hope this helps.
Jan 06, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer reads off on display
Not sure if its the same for all Kenmore freezer models but this may indicate it is in demo mode. To remove this press the up or down arrow three times as fast as possible (within 2 seconds). This will start the compressor, I hope this helps.
Dec 22, 2013 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My new frigidaire freezer digital display flashes off please help
Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
Nov 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My new frigidaire freezer the digital display on outside of door flashes off what to do?
Kenmore elite upright freezer service manual mod# 253.28093800
There is a lock on the display. Try pressing standby button for 10 secs
Apr 14, 2012 | Kenmore Freezers
Freezers Logo
89 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
