Question about Brother HL-2040 Laser Printer
Flashing red light - no paper jam
There is no paper jam - but the red light is flashing and the printer has paper
  • Carole Mikelson
    Carole Mikelson Nov 03, 2008
    The red light is flashing on the printer indicating no paper when in fact there is plenty of paper in the machine
  • joejl Dec 03, 2008
    The red light is flashing on the printer indicating no paper when in fact there is plenty of paper in the machine. I removed cartridge and there is no paper jammed. Now what?
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Posted on Nov 14, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
The red light with the arrow pointing down keep flashing and it won't print. It the print the first page just fine. What does it mean when the red light is flashing?
Its either a paper jam error or your printer is out of paper,open your printers back cover and check properly to see where the paper jam is located.
Jun 29, 2010 | HP Deskjet 5940 Photo InkJet Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Two red lights blinking
The flashing red light next to a page and bin indicates paper or a CD/DVD has jammed in the printer.
The flashing red light next to the drop indicates that the ink is low - if it is solid on then the ink is out.
Both of these lights flashing rapidly together means taht the print head carriage is obstructed by jammed paper or some other material and cannot return to the home position. Turn off the printer then open the paper support and the printer cover. Then remove any paper or other obstructions from the paper path by hand / tweezers. Then, turn the printer back on and the fault should clear. If the lights are stioll flashing then check the paper path again and see if the print head carriage assembly is jammed by gently moving it very slightly along the carriage. Don't force this or do this too hard or too far as you can cause some damage to the drive
Sep 11, 2009 | Epson Stylus Photo R200 InkJet Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
2 flashing red lights
The printer jams each time I try to print, and although I think it's clear, it still jams.
Mar 22, 2008 | Epson Stylus C86 InkJet Printer
Brother HL-2040 Laser Printer Logo
811 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
