E2 flashing on telmann washing machine
No spinning e2 error flashing
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
  • 3 Answers
SOURCE: Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Posted on Mar 04, 2009
  • 44 Answers
SOURCE: Error E2
A model number always helps when you're looking for help. ;)
I looked through about twenty manuals looking for an answer for you; I suggest that you'll have better luck if you have the model #.
Here's the link to the many, many, many Daewoo washer manuals.
WashingMachine&cpage=1">http://www.dwe.co.kr/english/support/download.asp?class1=5&class2=19&class3=0&selorderby=1&searchpath=WashingMachine=>WashingMachine&cpage=1
Good Luck!
Posted on Aug 08, 2009
SOURCE: E2 error on homemaker washing machine.
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Posted on Nov 08, 2009
  • 3 Answers
SOURCE: Heller awm600 washing machine e2 error on spin
A far better and safer way would be to replace the lid.
by wedging a stick in you are bypassing a safety feature and a child or person could sustain a serious injury by openg the lid placing their hand into the drum whilst on a fast spin
Posted on Mar 09, 2010
Tip
Toshiba washing AW-9771UBB error code E2
i get Error code E2.. its stop working with out spin.
on Oct 18, 2016 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Telmann TEL6TL washing machine doesnt spinn properly, brake motor not activated
replace whole mechanism if cheeper than replacing unit and dont want to pay a pro
Jun 19, 2012 | Washing Machines
Have a Avanti 798SS Washer. Does not wash nor does it spin. I heard something with the motor as if it attempting to perform said task (wash) but in the end it beeps and E2 flashes. What does this mean?
Oct 21, 2009 | Avanti Top Load Washer W797
E2 error on homemaker washing machine. I have tried eveything including reducing load down to one item. It goes through the wash cycle OK, but will not drain, then eventually flashes the E2 error on its...
Sep 13, 2009 | Washing Machines
Telmann washing machine TEL6TL
Telemann TEL6tl E2 Problem
E2 on screen means the lid is not closing properly and thus not activating the (hidden) switch that prevents the machine from spinning while the lid is up.
The lid switch in this model is not a direct contact switch between lid and switch , but it switches on and off due to a MAGNET embedded in the lid on the left hand side near the front. You will see a small indentation where the magnet SHOULD BE. My magnet had fallen off, so the lid could not activate the operation switch. I had lost the original magnet( about 1cm X 2cm) so glued another into place.
Machine is now fully operational again, and the job cost .78c.
If your magnet is still in place, the E2 fault could lay with the switch itself , which is fixed to the underside of the top casing of the machine near the front right hand side of the lid cavity. The switch measures 1cm X 3cm heavily black tape insulated. Access is gained by popping the 2 X2cm discs at front top of machine and releasing the 2 small philips screws here and a further 2 at the back top of machine. This operation of replacing the switch is best left to an electrician or washing machine specialist.
Hope that helps
Apostle95
Nov 01, 2008 | Dishwashers
Telmann washing machine 6kg has error 3 and it wont spin help
  • i have found with this washer usually E3 is that the magnet has come out of the top.. under the lid there is ment to be a little magnet black sits in the little gap to the right of the machine lid. without that it wont work properly. hope this helps
Aug 09, 2008 | Washing Machines
Telmann TEL12DWMS Motor hums but does not wash dishes
TELMANN WASHING MACHINE HAS CODE ERROR E 2 can anyone help
jane@nosnam.co.nz
May 03, 2008 | Dishwashers
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
