Question about Garden
Mower revs up and down
Pulled carby of and cleaned out put new air filter and fuel in still no good
  • kevin richards Feb 11, 2012
    THROTTLE IS CONNECTED TO CARBY AND I CLEANED OUT CARBY INCLUDING THE GAUZE ON THE CARBY INLET.
    Scholar:
  • 140 Answers
Gday mate ,geoff here, 2 solutions i can think of, 1st, most modern mowers dont atually conect the hand throttle to the craby, it goes to a lever in the top of the crankcase under the pull starter, and has a fan control via the amount of wind pushed onto the vain that then conects to the carbeuretter, this is a 2 fold system that stops the engine reving out of control, and also sets the engine throttle due to the load on the mower blades, the other one is that there will be a small gauze in either/both, the fuel tap and arby fuel inlet, hope this helped, geoff.
Posted on Feb 11, 2012
Testimonial: "thanks, Geoff."
5 Suggested Answers
  • 126 Answers
SOURCE: gas pouring out of air filter
carb is gummed up from the old fuel turning to varnish and clogging the jets. while trying to start, its trying to inject fuel, but its clogged and taking the path of least resistance (coming out the air filter).
you'll need to drain the gas tank and remove the carb to clean it out. if unfamiliar or uncomfortable doing this, then take it to someone to do a carb cleaning.
Posted on Jan 31, 2009
  • 143 Answers
SOURCE: 4.5hp B&S engine on a bolens mower..won't idle steadily
This is called hunting, your fuel-air ratio is not right. Your carb. jets need cleaned
Posted on Sep 05, 2009
Testimonial: "Thanks...always get great advice on here...."
daneinwv
  • 124 Answers
SOURCE: I have a Craftsman 625
My name is Dane and I am going to try to help you solve your problem.
I believe that you have clogged jets/passages inside of your carburetor. This can happen when an engine gets little use, allowing the fuel in the system to get old and begin breaking down. If fuel is left in a Carb for more than a year, it can eventually turn into a jelly like consistency, and clog the fuel system. What I believe is happening in your case is that the float needle inside the Carb is not allowing gas to enter the carb fast enough to keep up with demand. That's why it will run for 10 minutes and then shut down. After it sits for a while, the float bowl slowly fills back up and it will run for 10 more minutes.
Now for the bad news. This is an extremely difficult carb to work on. It is all I can do to get these Carbs off an engine and back on again to clean them. They are tough because you have a big air filter housing and 2 long bolts with gaskets and then the carb itself and spacers, that you have to hold together as a unit and start the bolts holding the carb to the engine. If you are a good enough mechanic to do this, you will already know how to do it. If not, I honestly suggest you take it to a shop and let them clean it for you. A new Carb isn't all that expensive, so you may want to consider just letting them replace it instead of cleaning.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thank you! Dane
Posted on Dec 04, 2010
daneinwv
  • 124 Answers
SOURCE: Have a B&S engine that will not stay running.
My name is Dane and I am going to help you solve your problem. I believe that you have clogged jets/passages inside of your carburetor. This can happen when an engine gets little use, allowing the fuel in the system to get old and begin breaking down. If fuel is left in a carburetor for more than a year, it can eventually turn into a jelly like consistency, and clog the fuel system. The other way to block these passages is to allow dirt or other debris to enter the fuel tank. This will be picked up through the fuel line, also clogging the system. The symptoms can be anywhere from a slight miss, to the engine not running at all. Always check your spark plug first before starting any troubleshooting procedures on an ignition system. Clean or replace it if it appears fouled, burnt or otherwise unserviceable.
You will probably need to remove, disassemble, soak, and use compressed air to blow out the jets in your carburetor. Pay close attention to how the carburetor is attached to the engine. Make a drawing if you need to or take some pictures. Remove the Carburetor from the engine. Remove the air filter, linkages, throttle/choke cables and fuel line. Remove the mounting bolts/nuts. You will need to disassemble the carburetor as far as possible and put it in some Carburetor cleaning solution. You can get this at any auto parts store. Do not place rubber parts in the solution. Allow it to soak in cleaner as directed, and then blow out the ports and jets with compressed air immediately after you take it out of the cleaning solution. Be careful not to get any spray back on your skin or in your eyes. Reinstall the Carburetor in the reverse order. Replace any worn or torn gaskets or o-rings as you assemble and reinstall it. Check the air filter and make sure it's clean and not oil soaked. Replace if needed. If you suspect your fuel was contaminated or old you should also drain, and flush your fuel tank. Dispose of your old fuel properly.
Just a TIP: Always mix your fuel with an approved fuel stabilizer. Fuel begins to go bad after a few months and that's why many people have fuel problems in the spring
I hope I've helped. Thank you! Dane
Posted on Dec 29, 2010
All 3 plugs keep fouling on 1972 Ford 3000
pull the carby and have it rebuilt professionally
it is over fueling (black plugs )
could be from float level , power valve , accelerator pump circuit
something is in wrong or missing
Oct 04, 2016 | Ford Garden
When I pump the primer bulb, why doesn't it fill with fuel and stays collapsed?
new carbies start around $25.00 us on e-bay so get a new carby
take it to a mower shop for a service
rebuild the carby using a new carby kit
Nov 28, 2015 | Husqvarna 125 Bvx Leaf Blower Lawn Yard...
Lawn mower running suggish
fuel problem???? ya know carb cleaner works on lawn mowers as well as cars .
Jun 07, 2014 | Poulan "Poulan" Push Mower
Toro lx423 inconsistant idle
drain fuel tank. replace fuel filter. strip down carby and give it a good clean and blow down with air put back together. fresh clean fuel and should be as good as new
Sep 14, 2013 | Toro LX423 42" 20-HP Kohler Lawn Tractor
Craftsman 18.5 42"
Hi, does it have a fuel shutoff solenoid in the bottom of the carby? if so has it got a rubber tip on it? if so remove the rubber tip and try it as the rubber swells and restricts fuel flow. Also remove all carby jets again and clean down through them using some twisted multi strand wire and carb cleaner and air. Just blowing air through wont remove varnish deposits etc from the walls of the jets. Let me know how you go, regards Phil.
Aug 20, 2012 | Craftsman Garden
I own a champion 35 petrol mower that starts first pull but seems to be searching for revs when running , don't know if I have some how set the two springs up wrong (the ones at side of carb) as I...
Hi its called "hunting" and is caused by a fuel block in the main jet of the carby. Pull the carby down and blow out all jets with compressed air. regards Phil.
May 30, 2012 | Briggs & Stratton Garden
I have a Victa Sabre 450 series 148cc B & S engine...9T702 Model 2129 B1 type 08012552 Code...have been thrown the task of mowing since Hubbie left me and have succeeded the past 4 times. But now it...
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.
Feb 19, 2012 | Garden
My kawasaki 23 hp model # fr691v on a toro 50 inch ztr from home depot started back firing. there was dirt in fuel filter so I changed it. changed the plugs and new air filter. Cleaned the carb. now thw...
hi there
if you had the carby off and cleaned it out , was the fuel flow from tank to fuel pump ( if it has one ) good , and was the output from pump to carb good on cranking?
if so and the breather in cap is venting , it could be that the governor needs adjusting, possibly have got a spring in the incorrect position and there is no binding , pay to check , carby main jet closly for any obstruction. check the fuel level and float hieght .
most times hunt / surge is caused by obstruction to fuel flow , or governor
try holding the governor in a fixed position if hunt / surge still apparent - carby is causing fault
but if not governor setup is causing problem
cheers pauly46
May 28, 2011 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
My 1991 suzuki gsf400 has erratic idling. also is hard to start.
This could be almost anything, probably minor. Good premium unleaded fuel, fresh/clean and gapped plugs, fuel filters clean,. Carbies clean and jets good, correct float levels, no air leaks in intakes, air filter clean, Electrical connections 100%, ignition coils OK, no sign of moisture behind magneto/stator cover or on source/pick-up coils. Engine earth wire secure from head to frame?
So....
New plugs, 0.7mm gap to start with and set air* mixture screw 1.5 turns out.
To flush carby with cleaning solvent (spray can from auto access.) Take float bowls off (check for sediment) and fuel lines off and spray till it pours out of float needle seat, Loosen carby clamps and swivel carbies outwards 90 degrees and unscrew pilot jets and spray thru also. Check operation and smooth return of choke.
* Air mixture screw controls fuel-air mixture at idle speed and is a trial and error thing. Pilot and Main jets regulate cruising and acceleration mixtures and ranges according to rider style and riding and climate conditions.
If there is any undue noise comming from the top of the engine with revs slowly rising from idle to 2000 revs, you may need to check camchain tension and valve clearances, easy done with some simple tools and a manual. Downloadable free with an engine search!
Goodluck and Cheers.
May 02, 2010 | 1991 Suzuki GSF 400 Bandit
Mower stutters when i turn up to full throttle.
Hi if it is older than 2 years it will need a new diaphram and gasket under carby you will also need to clean out the fuel bowl in the top of the tank this should fix your problem.
Apr 03, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
