Question about Exercise & Fitness
Orbit treadmill t92.2 heart rate
Looking for manual
    Top Expert:
  • 12,223 Answers
Dear Sir:
Go to www.fitness.manualsonline.com or www.iconservice.com and download for free. sincerely.
God bless you.
ernesto cuadra
managua, nicaragua.
Posted on Feb 17, 2012
  • 11 Answers
SOURCE: heart rate monitor chest band not working with Life Fitness 9500H
Enter the diagnostic menu and ensure the "telemetry" option is enabled in the managers config menu.
Posted on Apr 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: What lubricant can be used on the Horizon T92 Treadmill
Go to www.horizonfitness.com then click on e-store then look for part and accessories the silicon lubricant to purchase. Follow this procedure before applying lubricant.
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components.
2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition.
3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt.
Posted on Jul 16, 2010
Coachphil
  • 347 Answers
SOURCE: Does the odor treadmill measure
Are you sure you have the correct brand of Treadmill. Never heard of this one.
Double check your brand and model. IFIT is availalable on several brands and models of treadmills, it is possible that your treadmill only has heart rate grips and also possible it will do both.
Generally a treadmill that will work with a heart rate strap will say so right on the face.
Posted on Dec 06, 2010
Andriod Man
  • 271 Answers
SOURCE: I am looking for a user manual for the Orbit Venus
you can try ordering here :
http://www.orbitfitness.com.au/
Posted on Feb 09, 2011
valeantudor
  • 787 Answers
SOURCE: My treadmill stops after a
Are you sure that you are not just using a predefined program that automatically stops the treadmill then? Also, the heart rate monitor plug may just need unplugging then firmly plugging back in.
Posted on Feb 16, 2011
My heart rate monitor does not work when gripping the hand bars.
please follow the steps and fix it. God bless you
1) Make sure the heart rate monitor is under your clothing, against your skin, and as high under the pectoral muscles as is comfortable. Note: If the heart rate monitor does not function when positioned as described, try moving it slightly lower or higher on your chest.
2) Make sure the logo on the sensor is facing forward and is right side up.
3) Use saline solution (saliva or contact lens solution) to wet the two electrode areas on the sensor unit. If the heart rate readings do not appear until you begin perspiring, re-wet the electrode areas.
4) As you walk or run on the treadmill, position yourself near the center of the walking belt. For the console to display heart rate readings
5) The heart rate monitor is designed to work with people who have normal heart rhythms. Heart rate detection problems may be caused by medical conditions such as premature ventricular contractions (pvcs), tachycardia bursts, and arrhythmia.
6) The operation of the heart rate monitor can be affected by magnetic interference caused by high power lines or other sources. If you suspect that magnetic interference may be causing a problem, try relocating the treadmill.
7) If the heart rate monitor still does not function properly, test it by having another person try it.
Jan 22, 2013 | Ironman Exercise & Fitness
Does the odor treadmill measure heart rate without holding on to the grips
Dec 05, 2010 | Heart Interface Ifit Treadmill My Progress...
Give me an example of polynomial age word problems with solution.
After 2 minutes on a treadmill, Jenny has a heart rate of 82. After 3 minutes she has a heart rate of 86. Assuming that Jenny's heart rate H is a linear function of the time T on the treadmill, write H as a linear function of T. What heart rate would be expected for Jenny after 10 minutes on the treadmill?
Sep 22, 2010 | M2K Garfield: It's All About Letters and...
Inaccurate Measurements of heart rate
Replace the battery. Then make sure that it is placed on the proper artery that it is supposed to be on. If your heart rate was 210 you would be in the hospital with a heart attack. And also the only person I know with a heart rate of 90 when running is Lance Armstrong. Your heart rate should be about 120 to 135 and it will just around in those areas but should never go higher
May 22, 2009 | Polar F6 Wrist Watch
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
Mar 12, 2009 | Life Fitness 9500HR Next Generation...
Seeing heart rate displayed on my polar compatible treadmill
i didnt knwo my treadmill was compatible i just hooked up like i wanted to read from my watch and then both started to read...although the treadmill had a bit of a different reading
Jan 02, 2009 | Polar S410 Heart Rate Monitor
Proper use of functions of treadmill
Most manufacturers have their manuals available on the internet. Google for you machine model and perhaps you'll find it.
Jul 14, 2008 | Computers & Internet
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
