Question about Intel Computers & Internet
I have an old IBM Netvista 6794 pc with its original IBM motherboard that it came with P4 pc with a 2.0ghz cpu. Now I want to change the processor. My question is can a 3.6ghz or 3.4ghz p4 intel cpu work on this pc? Thanks.
  • Intel Master
  • 3,799 Answers
Unlikely, I would think that the best processor you could use would be a 3.0Ghz or maybe a 3.06Ghz. If you look at the motherboard part number you will be able to find out from the manufacturers what the fastest CPU is. A lot depends on the FSB on the mobo and the Bios version. You need a "Socket 478" processor I think you will find that the processors you are looking at are "Socket 775" ( this is the fitting socket for the processor) .
Posted on Feb 17, 2012
Semi-Driver
  • 434 Answers
SOURCE: how to install CPU- Intel Pentium Dual Core E5200
This particular CPU is not on the list of processors supported by this board. See "CPU Support List" tab:
ASUS P4-P5N9300 Spec
How to install Socket LGA 775 CPUs:
Lift up the cpu slot load plate (which covers the pins and also locks the cpu in place) and install the processor slowly, vertically and carefully into the socket without bending any of the tiny pins in the motherboard socket. Lock the load plate.
The advent of the LGA 775 form factor moved the tiny pins from the CPU to the motherboard socket. Great for Intel, not so great for motherboard manufacturers. Now bent pins are the responsibility of the board makers. Customers with bent pin problems are no longer contacting Intel.
Posted on Dec 27, 2009
shaky120
  • 310 Answers
SOURCE: Upgrade CPU In my SAMBA SM-1845
Hi, as long as both chips are slot 478 it should work fine, you wont need to change any bios or jumpers, just open up the computer, remove the heatsink, lift the lever and remove the CPU.
Insert new processor.
you will need thermal grease at this point, you need to apply a little amount onto the cpu, and make sure the old thermal paste is removed from the heatsink and then refit the heatsink & fan.
other option is fit the new cpu and purchase a new heatsink & fan, they usually come with the thermal grease, a new heatsink will cost about £10 or themal grease by itself will cost about 2-3 pounds.
just make sure you have new thermal paste before you remove the heatsink as the processor will get damaged otherwise..
Hope this helps
John
Posted on Aug 01, 2008
Crenshow
  • 250 Answers
SOURCE: NetVista M42 (8303xxc) Barebone: need drivers for ibm netvista 830912g...
Hi, Here you can find the drivers for your computer: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42954 Thanks and have a nice day ! J -
Posted on Jun 08, 2010
ardmax
  • 155 Answers
SOURCE: I would like to find a picture of the motherboard
Please go to the following link
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tindex.htm
and under "about your computer" select the link System Board Component.
You will see all the details inside your PC including a picture of the motherboard, if you need a more specific picture, looking in the same site you will find it.
Please let me know if you need further help.
regards
Posted on Mar 18, 2011
Testimonial: "After I asked for assistance, I kept poking around and before you sent your response I found the site you recommended. Your answer is right on!!"
MegaByteMe
  • 137 Answers
SOURCE: my pc is p4 intel borad but it's prosser fan
Check the fan and see if there are any obstructoins like wires rubbing on it, or dust on the blade. How old is the board?
Posted on May 27, 2011
RESPECTED SIR, SIR MERE PASS IBM KA PC HAI. MERE PC MEIN 1.86 GHz KA PROCESSOR THE USKI JAGAH MAINE 3.00 GHz KA PROCESSOR CONNECT KER DIYA HAI. AFTER CONNECT MY PC SHOW A ERROR WHAN I START THE...
As I understand it, you tried to upgrade the CPU from 1.86GHz to a 3.00GHz. The error message is stating that the BIOS (Basic Input Output System) cannot recognise the CPU because it is not in the list of supported CPUs. You need to download an updated BIOS (if available) for the particular motherboard in your PC. You will need to get the model number of the motherboard which is usually written on the motherboard. Then go to this web site: http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
Search for an updated bios for your motherboard. There should be instructions on how to update the bios.
May 25, 2011 | IBM NetVista PC Desktop
IBM 6794-75G IS NOT POWERING ON
Now please check the "smps" by another new or by your"smps" to another pc to confirm either it damage or not.
http://www.playtool.com/pages/psuconnectors/connectors.html
Hope this helps,
Feb 25, 2011 | IBM NetVista PC Desktop
Just installed xp for a friend on an old ibm netvista 6794 NZU pc. Went to ibm website but can not find the motherboard or chipset drivers to allow this pc to acess the internet. Can anyone help please. ...
It's a big pain when you dont have the right driver. but try this:
1. download and install the Windows Service Pack 3 (XP SP 3) in the computer and check if it works.
and how are you trying to connect to the internet? you might just want to put in an extra PCI network card, if you want to use the broadband or if you need the usb ports to work, try a PCI USB card instead.
either ways, make sure you have installed SP3 in that computer.
cheers!
Nov 17, 2010 | Computers & Internet
Celeron D 2.5 ghz to replace P4 1.7 ghz on 478 socket motherboard
Technically you can. You should also compare cache level and FSB between the two processors. You may find that replacing the P4 with the celeron may not be much of a again.
http://www.devhardware.com/c/a/Computer-Processors/Celeron-D-the-Little-Processor-that-Could/
Mar 17, 2010 | IBM Computers & Internet
Problems with 3 brand new PC 133 512 MB RAM in Netvista 6794
That last RAM probably is good. Many motherboards have problems using many different memory. All of the memory you have should be at least identical to ensure that they work. When RAM run at different speed or require a little more voltage, they will not let your motherboard boot. You can try mixing up the order you put the RAM in. Try putting the last RAM in the first slot by itself, the motherboard should boot. Then try the rest.
Also, whenever you add or change hardwares, you should clear the CMOS/BIOS settings.
Jan 06, 2010 | IBM (49P1599) Motherboard
Trying to upgrade cpu.
Here's a direct link to the service manual of the NetVista 8303-21A:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_pdf/24p2969.pdf
On page 13 of this manual:
Microprocessor (varies by model type): Intel® Pentium® 4 processor with 256 KB or 512 KB of internal L2 cache memory and Intel NetBurst™ micro-architecture.
It seems that the computer's motherboard does not support Intel P4 processors with more than 512 KB of internal L2 cache. That's why your P4 2.8GHz/1M/533 Prescott processor did not work.
You will have to either buy another processor with 512 KB L2 cache, or replace your motherboard with one which supports the new processor.
Dec 19, 2009 | IBM NetVista PC Desktop
IBM Netvista 8303 not saving settings.
make sure bios clear jumper on motherboard is onright
Sep 03, 2009 | IBM NetVista M42 PC Desktop
Ram upgrade problems IBM netvista 6794
You can try this site, it scans your system to see if your computer can run more memory than what is currently installed. it helps you find the right memory modules for your system and and an option for you to read reviews if available and if you want to buy it.
try this site: www.crucial.com
Please rate this solution
Dec 26, 2008 | IBM NetVista PC Desktop
Need to download updates for IBM Netvista 2gh Processor
to use your computer you need to put back your old cpu in .
then download the upgrade, and apply i.
after your bios is updated, your new plugged processor will be reconized.
Nov 21, 2008 | IBM NetVista A40p PC Desktop
Bios Problem
if you still can enter bios setup look for the advanced menu in the BIOS for "processor updating" or something like this and set to "disabled". Save the changes.
otherwise your motherboard perhaps is incompartible with cpu
for example cpu 133 and motherboard 100 or 66MHZ
please let me know the result.
Nov 27, 2007 | IBM NetVista A40p PC Desktop
Computers & Internet Logo
155 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
