Question about LG Audio Players & Recorders
I have an LG fb163 hifi, and no volume is coming from the speakers. They're connected but the volume display says hp volume? How do I sort it?
  • jakebaker696 Feb 24, 2012
    No there's nothing plugged in to my headphone jack
Alright, the exact same thing happened to me, and I just could not figure out what the solution was, so I thought what HP could sand for..then it hit me "HeadPhone", you have something plugged into your Headphone input, in my case I accidentally plugged my Portable device into the headphone input..
Hope this helped.
Posted on Feb 15, 2012
    No I don't have anything plugged into my headphone socket, the only thing that's plugged in are my speakers, which go in the back.
  • robydany88
    robydany88 Jan 28, 2013
    u could try to see if there's any problem with the headphone socket...try to hassle it a bit with a headphone jack.....see what happens
Why is my lg mcd503 mini hifi displaying protection when turn on.
disconnect speakers and do a master reset.
connect and if it comes back probably one of the speakers..test one by one.
Jan 04, 2017 | LG Audio Players & Recorders
I have an LG fb163 everything seems to function but no sound in the speakers
check mute button, source knob/button, speaker selection knob/button while its playing a cd or FM radio. Also if you have connected headphones the speakers would mute. Check the speaker connections. If the speakers are powered you need to connect them to a power source. If all these fail to produce sound consult a technician.
Oct 30, 2014 | LG FB163 DVD/DivX USB Micro system Shelf...
Hi :) i was wondering how i change the clock on my Lg dvd Micro HiFi system FB163. i hold clock then press Set and from there i dont know how to change the time.
The answer is on pg 12 of the manual, which can be viewed here:
http://ebookspdf.s3.amazonaws.com/gadget/LG-FB163-Manual.pdf
Press clock for two seconds.
use the track forward and back to set the type (12 hr or 24 hr)..
press set.
use track forward and back to set hour.
press set
use track forward and back to set minute.
press set
Jul 01, 2011 | LG FB163 DVD/DivX USB Micro system Shelf...
Hi, I was wondering if my LG DVD Micro HiFi System FB163, could play an the radio as an alarm? If so how?
Hello, To set a radio station as your alarm -
  1. Press and hold "timer" for two seconds.
  2. All the functions DVD/CD/USB/Tuner will flash for two seconds.
  3. Press "set" when the mode you want to be woke up by is showing.
  4. If you pick "tuner" then "play" and "record" will flash alternately flash in the display.
  5. Pick one by pressing the "set" button.
  6. Then select the preset station you want to wake up to.
  7. Now press set again.
  8. You will now wake up at the time and radio station you selected.
Regards, Tony
Mar 24, 2011 | LG FB163 DVD/DivX USB Micro system Shelf...
My LG FB163 has just started to turn off about 20 seconds after i turn it on. what do i do to fix this?
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 25, 2011 | LG FB163 DVD/DivX USB Micro system Shelf...
HOW DO I UNLOCK MY LG FB163 (MINI HIFI) WITH A DISC STILL INSIDE.
I try to eject the CD but it is say Lock On how do we turn it off
Dec 19, 2010 | LG FB163 DVD/DivX USB Micro system Shelf...
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
255 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
