With PC and TV both off, connect the cable for the monitor to the back of the computer, then to the jack on the back of the TV. Turn the TV,then the PC on. Essentially, you're just replacing your monitor with the TV. However, you may need to select the input on the TV to accept the signal on the computer. Also, you may need to adjust the resolution on the computer in order to get a picture
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 Ć 480 60Hz
SVGA 800 Ć 600 60Hz
XGA 1024 Ć 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
ā¢ The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
ā¢ Some PC models cannot be connected to this TV.
OK.
