Question about Gateway 505GR PC Desktop
I need to find the motherboard wiring diagram for a Gateway 505gr
Im in the process of thoroughly cleaning the tower and removed all cables from the motherboard. I did not change any pin/jumper settings. I lost my cheat-sheet diagram and need to determine which wires/cables go where...
  • 807 Answers
Look for a make and model number and version number on the motherboard, gateway use various manufactures motherboards.
Then go to the makers website and look in the support section for the moherboard manual. Most motherboards have the connections marked on the board in very small print.
Posted on Feb 11, 2012
4 Suggested Answers
SOURCE: need mini tower cover
I am trying to reasemble my old Gateway Tower 500. I can remember where most of the things go but I can't find the Layout Diagram that came with it. Have you any idea as to where I might find one?
Posted on Aug 21, 2011
SOURCE: replacing a mother board for a gateway 505gr
First off find out what form factor the tower will support. most new mob will tell you what form factor they are.
Posted on Dec 31, 2007
deathraider
  • 64 Answers
SOURCE: gateway 505gr motherboard replacement
not powering up does not mean the mother board is bad , the power supply going bad is more likely to be the problem . But your tower is considered to be a mini tower ive got the same one that I replaced the mother board on . dont mess up and get the wrong size board , it will not fit!
Posted on Mar 13, 2009
Proper installation of tower wires
According to Gateway Support, the Gateway 505GR desktop computer uses an Intel (Ausberg) 915G motherboard,
http://support.gateway.com/s/PC/R/3724/3724iv.shtml
http://www.ascendtech.us/itemdesc.asp?ic=MB4GWAUGSBURG
Scroll down to the photo with the sections marked in red.
In the top link, looking at the motherboard with the computer case open, the USB and Firewire (1394a) cables, can be seen attached to the motherboard near the letters D, E, and F.
In F that red cable is a SATA cable. One end attaches to the back of the SATA harddrive, (The angled end), and the other end of the SATA cable attaches to one of those SATA headers on the motherboard.
(SATA header = SATA connector on motherboard)
Preferred SATA header for the Harddrive is SATA 1.
DOESN'T matter though. That's the beauty of SATA. You can plug the SATA data cable into ANY SATA header on the motherboard, and BIOS will find the harddrive.
In the second link, looking at the motherboard photo shown, and comparing it to the view of the motherboard as mounted in the computer case, the Front Panel header is at the very Bottom Right.
Two rows of pins in a White rectangular shaped header,
(S points to Front Panel header)
[ The plastic front of a desktop computer is the Front Panel.
The area of pins on the motherboard, that the Front Panel wires go to, is the Front Panel header ]
A) Top row has Even numbered pins
B) Bottom row has Odd numbered pins.
http://www.intel.com/support/motherboards/desktop/sb/CS-009016.htm
1) Power LED = Power On LED light
2) Hard Drive Activity LED = LED light that flashes (Usually red in color) when your harddrive is active. Being used.
3) Reset switch = Reset Button. The Reset switch is behind the Reset button. (IF the computer uses a Reset switch)
4) Power Switch = Power On switch
5) Forget about Pin 9. That's for 5 Volts DC - Out. Used by factory.
Which wires coming out of the Front Panel, are the Power On wires, Harddrive LED light wires, Power On switch wires, etc.?
Remove the Front Panel, and trace where the wires end.
IF, the wires already installed coming from the motherboard to the Front Panel, are Too short, you should make notes before you remove them from the motherboard.
Note what color pair of twisted wires, went to where, in the Front Panel.
Compare to the chart of the Front Panel header given above.
(IF any wires are still connected to the Front Panel header on the motherboard)
Once the Front Panel is removed, it's usually pretty easy to trace the two wires up to the Power On switch.
Same for the Power On LED light.
Again, same for the HarDDrive activity LED light.
The SATA harddrive requires a DATA cable, and a SATA power cable.
The connector for a Data cable has 7 contact pins. It is the shorter connector.
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
The connector can be at a 90 degree angle as shown, or a straight connector.
IF the data cable has an angled connector, it plugs into the Harddrive.
Straight connector goes to the motherboard.
The connector for a SATA power cable has 15 contact pins. It is the longer connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note the L shape of the connectors for the SATA data cable, and SATA power cable.
Also;
This is a 4-pin standard Peripheral power cable. Commonly misnomered as a 'Molex' power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
IF, the SATA harddrive has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable.
Using both power cables will burn up the harddrive.
May not happen immediately in some cases, but WILL eventually happen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2011 | Gateway 505GR PC Desktop
Computer will not power up
I attempted to find this information for you and was unable to. Usually the type/model of the motherboard in a prebuilt PC is determined by printed information located by the CPU/Memory slots.
The downside to most prebuilt PCs you buy in the store, is these motherboards are generic motherboards. Gateway orders them from a company that makes them in bulk specifically for their needs. You would be better off trying to buy a new motherboard that matches the specifications of your current one. Here is the specification page for this Gateway PC. You would need to find a new motherboard that matched most, if not all of these features. However, worst case scenario, you may consider contacting Gateway to find out if they still have this board and how much it would cost to buy or have them replace it.
http://support.gateway.com/s/PC/R/4054/4054sp3.shtml
Mar 04, 2009 | Gateway 505GR PC Desktop
Gateway 505gr became unresponsive, on reboot windows cannot load
Hello guys,
This problem would arise only when the motherboard doesn't work properly. Check with your nearest gateway service center to get your CPU work again. That would be the only thing to be done.
~REGARDS,
Jegan
Nov 20, 2008 | Gateway 505GR PC Desktop
Gateway 505GR desktop...failure to start
when the power supply goes bad , that is the sign that it needs to be replaced . I would replace it first .
Aug 18, 2008 | Gateway 505GR PC Desktop
Wiring off tower into motherboard for gateway intel 850 motherboard scoket 478 mod. # 4000782
thanks for the help. but it ended being a inteldesktop board model D850EMV2. I now have all the paper on it from Intel, agin I say thanks for the help
Jul 21, 2008 | ASUS A7S333 Motherboard
Gateway 505gr motherboard replacement
Jul 17, 2008 | Gateway 505GR PC Desktop
New Harddrive
Most of the tower cabin are supprots scsi hdd please check whether it is IDE or the scsi harddrive .
Apr 28, 2008 | Gateway 505GR PC Desktop
Bad motherboard.gateway atx tower
whatever socket that is 454 soket mobo i think or befor ethat so old look on ebay for one that can take your chip how do u know mobos bad no power or im open for chat anytime also thx nick helpap
Jan 06, 2008 | Gateway (4000597) Motherboard
Replacing a mother board for a gateway 505gr
Dec 31, 2007 | Gateway 505GR PC Desktop
Need mini tower cover
Ebay has them for pretty cheap
Dec 07, 2007 | Gateway 505GR PC Desktop
Gateway 505GR PC Desktop Logo
361 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
