Question about Garden
Part left over
I recently changed the air filter on my lawnmower....Briggs and stratton 6.5 hp......LATER on my garage floor I FOUND A SMALL BLACK plastic fitting of some kind that probably covers something. it is about 1 inch by 7/8 inch ..black..and U-shaped. Where does it go?
    Scholar:
  • 36 Answers
Hi, that is probably the crankcase breather valve or part of it that is connected to your air filter inner housing.
All it does is stop the oil from contaminating the whole air filter with engine oil.
If you remove the filter again it should fit onto the pipe coming from the engine crankcase.
Posted on Nov 28, 2008
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
Small engine repair
First check the air filter isn't blocked. If it isn't the carb is at fault.
May 29, 2013 | Briggs & Stratton Briggs Stratton...
I have a 4 month old mcculloch with a briggs and stratton 450c engine , it starts no probs but then starts to blow out black smoke
Hi, check your air filter, also check your oil level is not over full as it may have become diluted with fuel. Let me know. Regards Phil.
Aug 30, 2012 | Briggs & Stratton Briggs Stratton...
Where do i find the spark plug to change it
there is a fat black wire next to the tin valve cover the plug is under the boot on the end of the wire
Jun 30, 2012 | Briggs & Stratton Briggs Stratton...
17.5 hp Briggs & Strattion has no spark
unplug the harness to the engine should be a 5-6 wire give or take then crank it look for spark if you get spark that way check the safety switches if no spark change the coil
Apr 24, 2012 | Briggs & Stratton Briggs Stratton...
What is the magneto gap for a 6HP Briggs & Stratton 12H802 series engine?
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Jun 10, 2011 | Briggs & Stratton Briggs Stratton...
I have a Briggs & Stratton Sprint 3.75 hp lawnmower and it seems the cord is pulled almost all the way out and won't retract. How will i know if it is broken? or should I be able to wind it back up...
You should be able to Fix this yourself if your a fair garage tinkering mechanic. However...I need the engine and type number off of the engine to get you parts information. The spring is broken in your recoil. It is a matter of removing the air shroud, taking off the pulley / spool and changing the spring.
http://www.ehow.com/video_2328977_how-install-lawn-mower-starter.html
and how to tension the spring:
http://www.ehow.com/video_2328961_how-tension-lawn-mower-starter.html
There are 2 different types of springs used so having your engine model / type number is important so that you can get the right spring. One of the 2 part numbers is: 390066
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Briggs & Stratton Briggs Stratton...
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
Garden Logo
190 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
