Question about Garden
Replace starter cord - Garden
    Sergeant:
  • 316 Answers
Hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,oh could you please rate this solution,thank you.``
Posted on Feb 18, 2012
How can I replace starter pull cord?
Hi James:
Replacing any starter cord is usually a matter of removing the pull start assembly, pulling the cord until it is completely unwound, block the reel so it cannot retract, remove the old cord, (remember EXACTLY how it was connected), install a new cord, unblock the reel so it can retract, re-install the assembly.
It may be necessary to remove covers or engine shrouds to get to the pull start assembly. That's part of the fun of "do-it-yourself".
Cheers..
Mar 19, 2016 | Electrical Supplies
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
Pull line broke.
Remove the starter housing from the engine, then unwind the rest of the cord from the reel. With both parts of the cord, measure the total length of cord plus some extra for knots. Take one of the remnants with you to a saw service shop for replacement cord purchase. You might even take the entire starter mechanism and have them rewind the cord for you if you don't feel comfortable about installing the new cord. When done, just reinstall the starter on the saw and attempt a start. Good luck!
May 17, 2010 | Garden
Cord broke for my leaf blower-how do I fix?
Remove the starter mechanism from the blower motor. Either purchase the same size cord from a saw service shop, or just have them fit a new cord to the starter if you don't feel comfortable about replacing the new cord. Good luck!
Starter cord won't rewind
The starter cord is spring loaded. When the spring breaks your cord won't rewind. Usually the whole starter cord assembly is easily replaced and readily available at your local gardening goods retailer. They might even install it for you for a nominal fee. I hope you find this solution helpful. Please rate it and thanks for using Fixya.
Nov 05, 2009 | Sewing Machines
Need to buy starter pull cord --- size??
take your cord with you and get something similar in size
Jul 22, 2009 | Garden
Pull cord broke on my lawn boy mower,new cord won't retract??
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind up the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Jul 16, 2009 | Garden
Positive cord from battery to starter
Methinks taht you have a bad starter. When you turn the key to "start", and you hear one click, that is def indicative of bad starter contacts, or the contacts are not coming together correctly. When you keep cycling the key, the contact plunger eventually moves, and then it will hit a "good spot" on the contacts, and then crankk. Aftermarket starters are notorious for this. Get a Toyota starter & install it, or take the starter to someone, and have them replace the contacts. This will def cure your issue. I do about 3-4 starters with this complaint a week here.
Sep 09, 2008 | 1990 Toyota 4Runner
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
