Question about Stihl Garden
Replace start cord on stihl fs 36 - Stihl Garden
    Sergeant:
  • 316 Answers
Hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,thank you. `
Posted on Feb 18, 2012
  • 6 Answers
SOURCE: pull cord is out and wont return. unable to crank stilh fs 45 we
Could be several things including a broken return spring. If you are not experienced with these springs please take it to a reputable shop to avoid any personal injury.
Posted on Jun 09, 2009
lemmingleejn
  • 173 Answers
SOURCE: Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Posted on Jul 25, 2009
mowerman1857
  • 389 Answers
SOURCE: Stihl FS 55 will not start
After trying to start several times, remove the spark plug and see if it is "wet" If it is you are flooding it. Do not pull the rope more than 3 or 4 times with the choke closed, whether it "pops" or not open the choke half way after the 4th pull and make sure you have the throttle trigger squeezed to give it gas
Posted on Sep 16, 2009
Dolfoff
  • 148 Answers
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
Posted on Sep 26, 2009
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
Sometimes when I try to pull start my Stihl Weedeater FS 36 it just free wheels and other times it will start. What could be causing this?
there is a small plastic finger in the recoil section that is broken . missing or worn out
get one from a service dealer or just about any mower shop spares
Jul 04, 2017 | Stihl Garden
I have a stihl FS 36 and I go to pull the rope to start is and the rope won't pull.
The rope pulley has either came off the pulley or the spring for the rewinder is jammed up you will need to take it a part and examine it to find the root cause. I am assuming the piston is moving and the ring is not broken or in other word there is no other problems.
Apr 22, 2017 | Stihl Garden
Replace on off switch on a FS 36 Stihl weed trimmer
yeah if its broken you can do that
Aug 17, 2016 | Stihl Garden
Stihl FS 36 trimmer doesn't have power, won't rotate.
Hi, remove the wire screen from the muffler outlet, regards Phil.
Jul 01, 2012 | Stihl Garden
Garden Logo
2,327 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
