Question about ViewSonic ViewPad 10 WiFi/Bluetooth 10.1" Capacitive Multi-touch Dual Boot Tablet (VPAD10AHUS01)
Viewsonic tablet 10.1 wifi problem - ViewSonic ViewPad 10 WiFi/Bluetooth 10.1" Capacitive Multi-touch Dual Boot Tablet (VPAD10AHUS01)
Tablet says i am connected to wifi but cant access anything online
Have you tried mutiple wifi sources to verify its the tablet or just your home wifi, reinstall the wifi drivers if possible....
Mar 02, 2014 | Archos ARNOVA 10b G3 8GB 10" Capacitive...
I use my mobile phone for wifi for my laptop which works well but my Audiosonic 10" T-22B tablet has trouble connecting to wifi even when the phone is sitting right next to my Audiosonic tablet the tablet...
If it is a cheap tablet, there are high chances that it might not even be able to connect to a wifi. Some cheaper laptops just don't bother putting in the Wi-Fi capability in them. Try to turn your Phone into a hot spot, and see if that helps find it. If not there is not much you can do regarding it.
Nov 05, 2013 | Apple ipad 2 wifi 16gb white
Is connecting to WiFi but cannot access the internet
YOU MAY HAVE WIFI but are you connected thru public or home network?
Aug 12, 2013 | ViewSonic 22" LED 1920X1080 Android OS -...
Wifi for my Tablet
Thank you for the Video, this made it much easier for me to determine the problem. You are correct, you have WiFi, this is not the problem, the problem is with the Tablet's WiFi Service which is freezing, thus not causing you to access WiFi.
Have you installed any new software lately? Something has broken the WiFi software on your Tablet. If you installed a new App recently, remove it to see if that new App broke your WiFi software on your Tablet. If you have not installed anything new on the Tablet maybe the manufacture downloaded an update that broke the WiFi on the Tablet. If you recently received an Software update from the manufature, let perform a Factory Resetr on the tablet to fix the issue.
Jun 11, 2013 | Tablets & eReaders
How to view wifi address on msi tablet
How can I connect to Internet on my MSI Tablet, it keeps saying "Obtaining IP Address"??????? PLEASE HELP!!!!
Jan 19, 2013 | MSI 10 Nvida Tegra 2 Cortex-A9 Android 2.2...
Hello! I have ViewSonic 10. It cannot see an external HDD. It was correctly (I suppose) formatted but anyway the problem exists. It sees a USB card ok.
The problem is that the Viewpad 10 does not have enough power at the USB port to push a standard external HDD. You will need an externally powered drive or a two to one usb cable for this to work.
Jul 08, 2011 | ViewSonic ViewPad 1000 Tablet PC
I purchased this tablet a couple of months ago specifically to take camping with me... However I have been at 2 campgrounds with wifi and am not able to connect ... we had a laptop with us and that...
Do you see the networks on you tablet? Ask at the campground where the wifi antennas are and go close. Somewhere in the settings for wifi you should be able to activate wifi if it isnt and then select wifi connection. They might have a login.
Good Luck.
Sorry im not that good with Android.
Jul 04, 2011 | ViewSonic G Tablet 101 Multitouch Android...
How to use keyboard/upper and lower case
Hi
Open the keyboard and touch the CAPS On and your Upper case, CAPS Off lower case word
Jun 26, 2011 | ViewSonic ViewPad 10 WiFi/Bluetooth 10.1"...
Good afternoon, I need the Viewsonic "VIEWSONIC TPC V1250 CENTRINO TABLET PC" drivers. Thanks Cesar Piquero onno@ono.com
Go through the below link.
http://www.viewsonic.pt/support/mobilewireless/tabletpc/tabletpcv1250/
There you can able to view the option to download the drivers.
http://www.viewsonic.pt/support/drivers/index.cfm
Select the options and download the drivers.
Please let me know if anything else.
Dec 13, 2010 | ViewSonic (TPCV1250FB2S) Tablet PC
ViewSonic V1100 Hard Drive
I called viewsonic and this is the part no. they gave me you can order it on there website http://store.viewsonic.com
Part No. M-MS-0808-7635
just run a search on it
May 13, 2008 | ViewSonic Tablet PC V1100
ViewSonic ViewPad 10 WiFi/Bluetooth 10.1" Capacitive Multi-touch Dual Boot Tablet (VPAD10AHUS01) Logo
110 people viewed this question
Top ViewSonic Tablets & eReaders Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
tosin_christ
Are you a ViewSonic Tablet and eReader Expert? Answer questions, earn points and help others
