Question about Abit KV-80 Motherboard
Added memory, now no boot, red LED on m-board lit.
Hi, just added an additional 1 gig dimm mem stick, being careful about static. PC won't boot. Tried clearing CMOS, and just about every combination. This is on an Abit KV-80 m-board.
No boot chirp, and there is a red LED on next to the green LED that comes on when power is available at the PS.
Any help with this is GREATLY appreciated.
Thanks,
Terry9@cox.net
  • 3 more comments
  • terry9230 Oct 23, 2008
    I did try installing the old single 512M stick, no difference. Just replaced the CMOS battery, thinking that could be a problem.
    I've been thru the manual again to no avail.
    As i said, when turned on, a small red LED lights on the m-board, and there is no video at all, no boot chirp, and I don't hear the HD spin up.
    Terry
    I did try just the old 512M stick in slot 1 where it was, as well as just the new stick as well.
    Just replaced the CMOS battery, thinking it could be a problem.
    Tried clearing the CMOS again.
    Still the same scenario.
    On turning it on: red LED lights on the m-board.
    no boot chirp
    no video
    don't hear HD spinning up
    Terry
  • compgeek09 May 11, 2010
    Did you mess with the power supply connections at all? Did it boot ok before you changed the memory the first time? Sounds to me like the power supply may be bad although I can not see that anything you have done would cause that. just to be sure check all the power supply cords to make sure they are plugged in, which I am sure you have already done, but it wont hurt to check again. Keep updating me so we can work through this.
    Thanks!
    Could also be a bios setting, but try what I said first and we will go from there.
    Did you try taking out the new memory and putting in what you had before to see if it boots then? If it boots with the old memory then there is probably a compatabilty issue with the new memory that you installed. Let me know?
3 Suggested Answers
sorose4u
  • 217 Answers
SOURCE: abit motherboard kv-85 manual and drivers
You can download the manual from the following link:
http://safemanuals.com/user-guide-instructions-owner-manual/ABIT/KV-85-_E
All the drivers for this motherboard are available on
http://driverscollection.com/?H=KV85&By=ABIT&SS=Windows%20XP
Posted on Feb 06, 2009
SOURCE: My Pc wont boot no signal in my monitor Help!
hi there..in mobo with platform p35 works the same like that on-off and on again,its normal so dont worry about that
the real problem is screen blank,i've got replaced new mobo with the same type,but the problem still the same.so its not the mobo problem i think.
Posted on Mar 29, 2009
Computer shut down and red light flashing five times then three second pause and repeats
According to the troubleshooting guide for this model, the red light flashing five times indicates a problem in the RAM (memory), before the video subsystem is ready. You may just need to open the case and make sure the memory sticks are fully locked in their slots. If you just added new memory, it might not match the required specs.
Blank screen and the power LED flashes Red five times, once every second, followed by a two second pause, and the computer beeps five times. (Beeps stop after fifth iteration but LEDs continue flashing.)
Cause Pre-video memory error.
Solution
1.
Reseat DIMMs. Power on the system.
2. Replace DIMMs one at a time to isolate the faulty module.
3. Replace third-party memory with HP memory.
4. Replace the system board.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01363877/c01363877.pdf
Jul 16, 2011 | HP Compaq DC5800 Small Form Factor PC...
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
Motherboard for compaq pcsr5109uk have upgraded to 1,5 GB this adding a 1 GB ram since doing this pc will not boot up,pc has said that the mother board has died this has only started since new ram have...
From what you have stated, the original ram memory was two sticks of 512MB.
It's PC2-5300
(DDR2 Sdram at 667MegaHertz)
When installing ram memory, and installing two sticks with one stick being larger, the larger stick of ram memory is installed in Slot 1.
This is the ram memory slot that is closest to the Processor.
(The Processor reads Slot 1 first)
On the motherboard it has DIMM 1 printed next to Slot 1.
The 1GB stick should go into Slot 1 (DIMM 1), and the 512MB stick should go into Slot 2 (DIMM 2)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077654&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3457899
Scroll down for the motherboard illustration, and photo.
Won't boot up with the original ram memory installed again?
1) What type, and size of 1GB ram memory did you install?
2) What ram memory slot did you install it in?
3) Did you follow anti-static precautions BEFORE you put your hands inside your computer, and BEFORE you took that ram memory stick out of it's protective anti-static bag?
[Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
You may not even see it, or feel it.
Poof!
No computer.
Computer unplugged from power, computer on a table, computer case open, TOUCH the metal frame to relieve your body of Static.
{A couch, bed, or directly on a carpet floor are HIGH areas of Static]
Before you answer my questions try this;
If the two sticks of 512MB PC2-5300 are still installed, follow anti-static precautions, and remove them.
Take a pencil eraser, and clean the gold plated contact pins on the bottom of each ram module. (Stick)
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(The above example is DDR Sdram, not DDR2 Sdram. I posted the link so that the gold plated contacts are clearly shown.
DDR Sdram has 184 contact pins.
92 on each side.
DDR2 Sdram has 240 contact pins.
120 on each side)
Remove the eraser dust with air. Use a can of compressed air for computers, or air pressure from your mouth.
Reinstall the ram memory modules.
Computer unplugged from power, press the Power On button in.
Hold the button in for a count of Five seconds.
(Count 1001, 1002, 1003, 1004, 1005)
Let go of the Power On button.
Do this procedure two more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS back to the factory settings.
Plug the computer back into power.
WAIT 1 minute, then turn the computer on.
I await your findings, and answers to my questions.
Jun 04, 2010 | Computers & Internet
Mem Test Failure Replace Dimm
The biggest problem with the P3005 is the main board. There has been a warranty extension on the P3005 if it is the main board.
it maybe a memory problem too, but unless you added memory, its usually part of the main board.
Jun 02, 2010 | HP LaserJet P3005n Printer
I have a D845GRG with 2 512mb installed can i have a 1gb mem mixed with a 512mb if i can where to place slot 1 or 2? So I increase my memory to almost 1.6 gb,from the 1028mb I now have..Thanks for any...
Motherboards that have only two memory slots do not require the memory to be matched DIMMs. You can mix and match whatever sixe you have and it does not matter what slot they go in.
Jan 17, 2010 | Intel D845GVSR Motherboard
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
Did you fix your problem with the VKM400AM-S not booting, only beeping?
Probably your mobo does not support 1 GB RAM in one DIMM slot.. Check Motherboard Manual.
Jun 19, 2008 | AOpen vKM400Am-S Motherboard
Abit KV-80 Motherboard Logo
56 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
