Question about GE Ovens
Ge profile stove model number pt916bom1bb button display does not work
Clock display works. The clear/off button makes a beep but no other button works. What can the problem be and how do I fix it? Ge profile model pt916bom1bb Thanks David.
Powerman
  • 68 Answers
SOURCE: F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Posted on Nov 04, 2007
Powerman
  • 68 Answers
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Posted on Feb 07, 2008
SOURCE: replacing glass top on stove
I also have a ge spectra with a broken glass.
Posted on Jun 26, 2008
  • 3 Answers
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Posted on Oct 03, 2008
  • 111 Answers
SOURCE: F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Posted on Jun 18, 2009
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Displaying F1 error
    How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
    1. Disconnect power to stove
    2. Gain access to the back of the clock (electronic range control or ERC).
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
    4. Make sure everything is clear and will not short out when power is turned back on.
    5. Turn power back on to stove.
    6. Watch for the F1 and listen for the beep.
    7. If you get the F1 and beep, replace the ERC.
    8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
      NOTE: Some models incorporate the touch pad and the clock as one part.
    Apr 04, 2010 | GE JGRP17 Gas Single Oven
    F1 beeping
    hello there:
    Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
      NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
    Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
    GE Profile oven beeps and displays FO
    Your electronic oven control(clock) is bad and must be replaced.
    Sep 02, 2009 | GE Ovens
    Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
    F0 error code on ge profile oven
    Could be a stuck keypad. Try pressing all pads at random several times each to clear it.
    If that does not work the ERC(clock) must be replaced.
    May 26, 2009 | GE Profile JTP18 Electric Single Oven
    Display is blank, no heat no bake
    The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
    Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
    hutchipop@yahoo.com
    Good Luck,
    Charlie Popeck,P.E.
    Consulting Engineer
    Feb 06, 2008 | Ovens
    Random beeps, oven almost starts itself
    The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
    Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
    Clock Display
    Press and hold the bake and broil pads together for 2 seconds. SF should appear in the display. Press the clock pad, it will toggle between 12, 24, and off for a black display. Toggle to 12 and press start...Catriver..post back.
    Oct 08, 2006 | GE Profile JT912 Electric Single Oven
    Ovens Logo
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
