Question about Singer Sewing Machines
The handle on my sewing machine stop turning up or down
  • Singer Master
  • 7,365 Answers
Could you please explain your problem a little more?
Posted on Feb 11, 2012
Machine stops when needle is moved up or down
Five Common Sewing Machine Mistakes + How to Fix Them
www.tillyandthebuttons.com/.../five-common-sewing-machine-mistakes-...
Sep 23, 2014 - Sometimes the needle will push the edge of the fabric down into the ....also helps stop that problem, too .... makes for very frustrating sewing .... handwheel wont turn and so the needle doesn't move up and down, please help.
Trouble Shooting a Sewing Machine - YouTube
? 2:35
https://www.youtube.com/watch?v=A2QqmEh5qcw
May 25, 2009 - Uploaded by MonkeySee
my machine needle won't go up and down on a white sewing machine. ... won't go up and down it'll go but then it will stop moving after i push ...
Nov 30, 2015 | Sewing Machines
The shank handle doesn't work, how to fix? It has a lot of play in it.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? g
May 17, 2015 | Sewing Machines
Stop start button is not turning green when I put the foot down
Is the foot correctly attached? Is the machine clean? Bobbin winder on or off? Try turning it off again crisply.
Feb 25, 2014 | Juki Hzl-K85 Computerized Sewing Machine
Sewing machine stops sews a minute slows down or stops then starts up
I suggest having the machine checked at a sewing machine shop
to see if there is something wrong with the motor, or the foot pedal
but first check to make sure the power cord & foot pedal are
connected correctly
Aug 20, 2012 | Singer Sewing Machines
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Feb 01, 2012 | Sewing Machines
How do i make the needle stop in the down position instead of the up position? New Home MX3123
You can't - it is only designed to always stop in the up position, then you can manually push the "needle down" button to make the needle go down while you turn a corner. The next model up the 4263 had the "stop down" option. Sorry.
Oct 25, 2010 | New Home MX-3123 Computerized Sewing...
The machine stops working and the handle will not turn
make sure you have properly lubed the machine ... your trouble is likely lint buildup or a scrap of cloth blocking the rotation of the mechanism under the machine ... you will have to take off the sole plate and remove anything that shouldnt belong there .. if that is not enough you may have to remove the bottom and check ... make sure the needle is going thru the sole plate hole and clearing the foot ... if its not then check for a bent needle or one that is in backwards (with respect to the flat side) .. you can check the motor to make sure its working ok by putting the machine in the bobin winding mode .. that disconnects the motor from the internal mechinism ... only the handle should turn in that mode ..
Oct 20, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
22 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
