Question about Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard Drive
The hard drive don't running
    Problem Solver:
  • 30 Answers
Check connections. If that doesn't work, try putting it in a different computer. If that doesn't work it's probably broken.
Posted on Feb 11, 2012
Wont boot up
Is your hard-drive OK? Run a diagnostic to check it. Please elaborate what OS was it? What laptop you have? May be some files have corrupted. Make sure your disk is OK & then reinstall the OS. If its Windows 7, chances are that you wont even lose data provided you don't format it.
Aug 12, 2012 | Computers & Internet
02 AVALANCHE 606.000 RUNS EXCELLENT FOR 5 MILES THEN SPITS SPUTTERS STALLS RESTART FINE THEN RUNS SMOOTH PORRS LIKE A KITTEN
Do you have any OBD Check Lights on your dash?
Any stored codes?
Don't see the intake question,same,
worse,still has to be fixed
I would suggest you drive around with a mechanic
& have that person bring along a professional grade
scan tool or software & see what data shows up.
If that isn't done, there is a good chance you will be told
they couldn't find anything,that happens way too often
You don't get what you go to a repair shop for & they don't
seen to understand why your there.
May 07, 2012 | 2002 Chevrolet Avalanche
Can't access files on external hard drive
Hello Amelia.
For your problem please connect your external drive and try these steps.
go to start
right click on my computer
click on manage
then click on storage
then click on disk management
then right click on your device and select change letters and path
window will pop up then click on add
select any letter not in use and click on ok.
I Hope this helps. Dale
Dec 20, 2011 | Seagate 1TB FA GoFlexDesk USB20 Blk
I just bought a new lap with ST9250315 AS HDD and i can't install winXP on it. First setup crashed, but i changed the BIOS setup for IDE instead of AHCI. After that installation goes ok until i...
Sometimes, recent hardwares (laptop components) don't have its drivers for XP1 & 2. (It conflicts.)
Try with XP3. Otherwise, you have to reinstall win7 and run win XP virtually under win7.
May 26, 2011 | Seagate Momentus 5400.6 (ST9250315AS) 250...
My PC recognizes my hard drive but it's making a ticking sound & it won't re-format. I'm running Win7 & have tried both reformat settings-NTFS and exFAT but there is not action at all....
I'm sorry to hear that your hard drive is having trouble. Based on your description of the "ticking sound" and the fact that the drive was dropped, the drive is probably physically damaged. Unfortunately, this means that your drive is failing in a way that isn't fixable; it will have to be replaced.
May 26, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
My dell Inspiron 1525 keeps stalling when loading and then I cannot do anything at all, as it freezes up.... I am typing this from my desktop I tried to system restore it...to no avail I tried to...
Try to check your disk here is a link to explain using your installation windows disk
If you don't have a disk you can probably find one on the net or borrow one..
Start your computer press F11 start from the cdrom with disk in and press r for repair when prompt
http://technet.microsoft.com/en-us/library/bb491051.aspx
You can also take the hard drive out and connect it to another computer as a second drive and run that computers command prompt.. Type CHKDSK (Your Drive: ) /F /R... on ..Example mine says CHKDSK D: /F /R press enter type Y for yes and enter don't turn off the computer.. when it is finished type EXIT and put HDD back in the another computer and start it
You can also try safe mode command prompt
After run Malware bytes to remove the mal -ware that is freezing the computer...the link Here
If you can get the malware installed and ran in safe mode you won't need to chkdsk but checking the disk is good because if fixes bad sectors on the drive also files...Made my hard drive run smoother and makes no noise..
Apr 02, 2011 | Dell Inspiron 1525 Notebook
It make tic noise when the hard drive is running
This sound is the heads of the disk hitting. The drive should be backed up immediately to another.
You can put this drive into a drive enclosure to clone it to another.
This drive will stop working and there is no telling how soon that failure will occur.
Jun 06, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Open Questions:
I used the HDDScan tool and it gave me these 3 errors. HELP "Reallocated Sector Count" Num Attribute Name Value Worst Raw(hex) Threshold 001 Raw Read Error Rate 100 100 0000000000-0000 050 002 Throughput performance 100 100 0000000000-0000 050 003 Spin Up Time 100 100 0000000000-01E9 001 004 Start/Stop Count 100 100 0000000000-0038 000 005 Reallocation Sector Count 100 100 0000000000-0740 050 007 Seek Error Rate 100 100 0000000000-0000 050 008 Seek time Perfomance 100 100 0000000000-0000 050 009 Power-On Hours Count 100 100 0000000000-0015 000 010 Spin Retry Count 101 100 0000000000-0000 030 012 Device Power Cycle Count 100 100 0000000000-002D 000 191 G-sense Rate/Servo tracking 100 100 0000000000-0002 000 192 Emergency Retract Count 100 100 0000000000-001A 000 193 Load/unload Cycle Count 100 100 0000000000-0079 000 194 HDA Temperature 100 100 38 C 000 194 HDA Temperature Maximum 100 100 43 C 000 194 HDA Temperature Minimum 100 100 19 C 000 196 Reallocation Event Count 100 100 0000000000-003E 000 197 Current Pending Errors Count 100 100 0000000000-0048 000 198 Uncorrectable Errors Count 100 100 0000000000-0000 000 199 UltraDMA CRC Errors 200 200 0000000000-0000 000 220 Disk Shift 100 100 0000000000-0045 000 222 Loaded Hours 100 100 0000000000-0009 000 223 Load Retry Count 100 100 0000000000-0000 000 224 Load Friction 100 100 0000000000-0000 000 226 Load-in Time 100 100 0000000000-0137 000 240 Heads Flying Hours 100 100 0000000000-0000 001
Nov 22, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard Drive Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
