Question about Sony KDL32EX600 32 in TV
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted
3 Suggested Answers
JoeO700
  • 80 Answers
SOURCE: vertical line black or out
Hello, The line appearing on your screen is probably the result of a connection problem on one of the address buffers located on the top and bottom section of the panel. These buffers feed the data signal to the panel to "address" which pixels should light and for how long. The other cause would be a bad display panel in which case the entire panel would have to be replaced, this is normally NOT the case. I hope this helps you. Good Luck. Joe Weibel CustomElectronics.Org
Posted on Apr 24, 2007
tvhelp-Dave
  • 178 Answers
SOURCE: ghosting on one side of screen on start up, then goes away
The T-con board failure or LVDS cable connection loose may cause the problem, you can try to reconnect the LVDS cable first.
Knowledge obtain from: Real case of repair by myself.
Posted on May 09, 2010
Light blinking 4 times and no picture
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
If you wish to get more details, check the site linked here.
Nov 27, 2013 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Kv 27542
  1. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Jun 27, 2013 | Sony Televison & Video
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
Jul 03, 2012 | Sony KV-27FS12 27" TV
KV-34hs420 LED Blinks 4 times
Apr 28, 2012 | Sony KV-36XBR400 36" TV
Red light blinks 4 times, no video or audio
Apr 27, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
I have a sony KV21DA1 no audio no video when turned on the green light blinks in rapid succession and then switches to red light and in 4 succesion and then repeats in interval
Four blinks means
Hope this helps.
Mar 02, 2011 | Sony Televison & Video
I have a sony trinitron kd-32fs170....all i get is 4 red blinks no picture
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
No frame in other words.
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Turns off after 2 or 3 seconds then red light flashes 4 times
Keep us updated.
Dec 22, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Tv shuts off then standby light flashes 4 times
hello Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
regards
shaun
Jan 20, 2010 | Sony Televison & Video
Won,t turn on.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. check the vertical deflection IC and circuit
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KDL32EX600 32 in TV Logo
244 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
