Question about LG 37LG30 37 in. LCD HDTV
Hi i have a problem with my lg plasma tv the remote was working then it stop n i have another tv same brand n remote works on that one so i think its the tv sensor but i need a different opinion.
If u dont get new remote go an program another remote for it
Posted on Jun 18, 2012
TVtechmaniac
  • 140 Answers
SOURCE: LG plasma
Yes,there is a cable RF connector on the back of this TV (see diagram). After you connect the cable you need to access the menu to autoprogram the channels.Since you don't have the original remote to do this,you might be able to work thru the menus using the menu button on the TV itself.
Posted on Oct 06, 2007
SOURCE: LG 42PB4D 42" Plasma TV
Search remote codes for Goldstar instead of LG or try 11265, 10178, 10700, 107856
Posted on Jul 01, 2008
SOURCE: Plasma TV smell?
I imagine it is the new silicone grease coatings on the electrical components. These tvs tend to run hot and it should burn off after a few days.
Posted on Dec 28, 2008
cseian
  • 138 Answers
SOURCE: I have a 42pc3d LG plasma and the remote controls
if your TV warranty is not out of date then claim a new one..however it takes many days to process
so I recommend you to troubleshoot your universal remote controller
i assume that you are using RCA universal controller
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE
SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR LIGHT will blink once then remain lit.
Note: For AUX, press DVD•AUX then the device button for the code you are retrieving.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad, press the number buttons in order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have retrieved all three numbers in code..
RCA: 004, 005, 006, 012, 019 ,056, 057, 058, 155, 156, 171, 172
if it fails buy and try ge universal remote
NOTE
it is a good to note down down your code
Posted on Jun 14, 2010
SOURCE: my lg 42pc5d tv remote sensor quit working. I am
The remote on my 42LG50 tv does noot work anymore. It worked fine for a year then quit. Also my comcast remote does not work either.
I replaced the remote sensor in the tv and still the rmote does not work.
Posted on Jul 14, 2010
My LG plasma TV will not hold the volume and when volume icon is displayed on the TV the remote will not work
Hi Peter,
I have seen in an another brand of LCD tv where the main board has to be replaced for this fault. Please contact the company service center. That is the only way. Good luck.
Feb 08, 2015 | LG Televison & Video
42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Remote On/Off not working - Sensor Broken
Hey, maybe you should try reprogramming your universal and see if that works. Might want to try testing all the codes that work for LG and see if they'd work. If that doesn't work, find a site like <a href="http://www.remotecontrolhookup.com/lg/">www.remotecontrolhookup.com/lg/</a> and see if you can find your original and buy it and try it out. If that still doesn't work, send it back and you may need to find a local tv repair shop to look at your tv rf sensor.
Jun 05, 2012 | LG 42PC3D 42 in. Plasma Television
Lg 42pg20 remote won't work how to program
Hello
Buy a univesal remote control, which have setup codes for LG tV. You can get this information from the catelogue accompanied with the remote control. There will be proceedings also to setup the remot to tV. Or get its orginal remote control from the authorised service center for LG at your town.
Feb 27, 2012 | LG 42PG20 42 in. Plasma HDTV
Remote not working anymore for my LG 42PQ20. Ive tried changing
call LG if you think the TV is not accepting the signal from the remote the TV may have a fault in it. If you have any universal remotes try programing them to control the TV if they work but the other does not it is remote.
Mar 15, 2010 | LG 42PQ30 42 in. Plasma TV
Remote problems
Replace batteries of your LG remote.
Oct 11, 2008 | LG 50PC5DC 50 in. Plasma HDTV
LG remote control
i have a lg tv that did the same,lg came out and changed the mother board.worked for 3weeks and has started again.im lucky ive been offered a full refund. as i only had it 8weeks. this is a known fault to lg. if i were you i would call lg and kick up a fuss.try and get your money back or a free motherboard. as for me i wouldnt touch an lg item again. hope this has been some help
May 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Lg remote codes
Programming u-verse remote for LG4270 (LCD 42inch) worked fine with code 1346.
This is a "Plasma" code according to U-Verse technical support, but was suggested with perfect result.
Jan 05, 2008 | Directed 434MHZ Remote Control
This worked for me too! THANKS
Dec 04, 2007 | LG 42PB4D 42 in. Plasma HDTV
LG 37LG30 37 in. LCD HDTV Logo
78 people viewed this question
Computer Repairing
Computer Repairing
