Question about Edimax PS 3100A+ (PS-3100A) Print Server
Edimax PS 3100A+ IP reset
I bought a Edimax PS 3100A+ but I don't know the IP. How can I reset the IP to the default IP? Thanks for Your Help. W.E.
  • Anonymous Nov 05, 2007
    I habe
First you must connect to the printer using lpt port. then that server automatically printing its information about it. example: IP address and ...
Posted on May 01, 2008
My edimax wireless access point is saying i have the wrong username and password and wont let me login
For most Edimax routers, the default IP address is 192.168.2.1, default username is admin and password is 1234.
By default the router is a DHCP server which will assign IP address starting from 192.168.2.100 to 192.168.2.199 to DHCP clients automatically.
Make sure your computer has TCP/IP Protocol setup as "Obtain IP address automatically".
Open the Internet Explorer.
Type in http://192.168.2.1 hit Enter.
The Login window will appear.
Type in the default username admin, password 1234.
Click on Login.
Then you can configure the router.
Sep 11, 2013 | Edimax Computers & Internet
Ew-7228apn cannot be reset
Press the RESET button and hold it for 20 seconds to reset the access point to factory default settings. The default IP address, admin user name and password are written on the back of the router.
http://us.edimax.com/edimax/mw/cufiles/files/download/manual/transfer/Wireless/EW-7228APn/EW-7228APn_Manual_v1.1.pdf
Feb 28, 2013 | Edimax Ew-7228apn 150mbps Wireless 11n...
Can't connect to my edimax ar-7284wna router
theres a temporary solution... reset router and change the date on your computer to 1 febrauary 2010 and you will be able to login. you can set all your details and even if you change your date back to current it will not affect your settings however to log back into the router you need to set back your date to feb 2010..
Hope this works.
May 30, 2012 | Edimax Computers & Internet
Printer Server - Fprgetten Password
If it helps, here is a link to the user manual for that print server. Good Luck!
http://www.edimax.eu/images/Image/product/PS/PS-3205UWg/manual/PS-3205UWg_M.pdf
Jun 15, 2009 | Edimax (PS-3205U) Print Server
I need ot reset my edimax ew-7206APg but the reset button doesn't
According to the manual (which you can find by doing a search in google for Edimax), the default IP address for the device is
Default IP Address: 192.168.2.1
You can open an internet browser window on the computer that is connected to the WIRED port on the router.
In the browser window, type
http://192.168.2.1 <return>
You should be able to see the screen that is generated from the Edimax and take it from there.
Manual location -
http://www.edimax.ie/images/Image/manual/Wireless/EW-7206APg/EW-7206APg_PDg-Manual-EN.pdf
Mar 31, 2009 | Edimax EW-7206APg (EW7206APG) 802.11b/g...
No Ports available
The default IP in the D-Link router is 192.168.1.x
The default IP in the Edimax is 192.168.2.2
Your 3rd octet (the # after 168) has got to be the same for the two of them to communicate.
So, you can either reIP your router, or connect your PC to the print server and change it. The software for the print server should have a tool for finding the PS by MAC address, then you can go in and reset it to 192.168.1.x
Sep 17, 2008 | Edimax PS-1206U (PS1206U) Print Server
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
Edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address 192.168.2.1 (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
Jul 06, 2008 | Edimax BR-6104K Router (br6104k)
Edimax PS 3100A+ (PS-3100A) Print Server Logo
867 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
